How to properly remove and replace front speaker grill - RESOLVED
Old Jan 16, 2018 | 11:23 PM
Spirit's Avatar
Default How to properly remove and replace front speaker grill - RESOLVED
2010 xf California
Last edited by GGG; Jan 19, 2018 at 03:03 AM. Reason: Add "RESOLVED" to thread title
Old Jan 17, 2018 | 02:07 AM
Welcome to the forum Spirit,
I've moved your question from General Tech Help to X250 forum. Members here with the same model will be able to help.
You should add detail on which sound system is fitted to your vehicle.
Old Jan 17, 2018 | 06:21 AM
EXEF's Avatar
Default Good luck
If it's this type, there are metal clips holding it down. To remove it, you need something very flat and 2 to 3 inches long (like a plastic spatula) to ease into the gap between the leather and speaker grille on each side. Then gently pry it upwards with your chosen levers as evenly as possible on both sides at once. Having said all that, don't be surprised if it shatters into a thousand pieces because no matter how careful you are, most of the ones that have been subjected to hot summers for several years become very brittle and unforgiving. Be very careful not to let any of the metal clips fall into the top of the dashboard as the grille comes out.
To replace it, simply push it back down into place but once again, gently and evenly as possible.
Attached Thumbnails How to properly remove and replace front speaker grill - RESOLVED-_20180117_223724.jpg
Old Jan 18, 2018 | 12:19 AM
Spirit's Avatar
Default Front speaker grill replacement
Purchased new grill from dealership and it popped right in.thanks for the tip EXEf.
JimC64
Sep 22, 2025 02:52 PM
Cambo
Sep 17, 2025 09:38 AM
nineball
Dec 28, 2013 04:19 PM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
Sep 10, 2009 12:44 PM
