How to remove xenon headlight bulb ('12+ facelift)?
Old Nov 13, 2018 | 03:23 PM
hendogg8's Avatar
Default How to remove xenon headlight bulb ('12+ facelift)?
I tried turning ballast in either direction but it won't budge and I'm afraid of using too much force. I know the connector should just pop down when pulled, but that's hard as well. Doesn't help that there isn't much room to work with.
Old Nov 13, 2018 | 03:58 PM
OzXFR's Avatar
It looks very much like the Xenon lights on my F-Type, and I had the same problem at first - turning the "ballast" and getting nowhere fast (PS - that square metal box on the back of the globe is not the ballast, it is the igniter which is integral with any D1S or D3S globe, the ballast is a separate "box" on the back of the light assembly).
The trick on my F-Type was to instead turn/twist that black plastic ring you can see just behind the igniter, it is in fact a locking collar which turns independently of the globe/igniter.
I can't remember which way I turned it now, and if memory serves it unlocked after about 60 degrees of turn.
Old Nov 13, 2018 | 04:00 PM
hendogg8's Avatar
Thanks Oz, going to give it a shot!
Old Nov 14, 2018 | 07:41 PM
BritCars's Avatar
Yes. I just did mine recently and Oz is spot on. Twist that collar - anti clockwise I think. Then it unlocks and opens up on a hinge so you can get the lamp out
Old Jan 30, 2024 | 02:57 PM
andreww2020's Avatar
I have a 2012 facelift XF (2.2D Luxury). The nearside (passenger) inner headlight bulb (the one nearest to the grill that flashes orange/amber once when you central lock it) has gone. Left indicator a bit dodgy as a result, like the relay has gone. I know there is a cover behind the main dip beam of the unit to change that bulb, but there does not seem to be a cover for the orange/amber one next to it...? Has anyone managed to change this one successfully - if so, how? Or do I have to replace the whole unit because the clever person who designed this unit didn't factor in that the orange/amber inner bulb could fail? Any advice would be much appreciated. Thanks in advance, Andrew
04xtype04
Apr 28, 2021 06:54 PM
benscott82001
Oct 5, 2015 09:45 PM
benscott82001
Jul 9, 2015 03:47 PM
xk_mike
Aug 5, 2010 02:08 AM
