I have a 2010 Jaguar with a wire harness issue and I'm mad about it.
My wire harness is trash. The design, improper routing, or perhaps the wire harness manufacturer went cheap on the insulation. At this point I don't really care, I just don't think a 2010 Jaguar XF should be having this issue. I've owned a Tahoe for 20 years and never had an issue with the wire harness so I wouldnt think that Jaguar should either. If there are others of you out there who have had an issue with their wire harness i.e. wires breaking let's join together to make some noise. Perhaps we can get Jaguar to take responsibility and fix this issue. I have a 2010 XF with a wire harness issue and I'm mad are you?
A 20 year old tahoe has nothing in the way of technology and need for hi speed communications that your car has or even newer ones. Wiring harness issues can be a problem in any car, well except the ones with pedals for kids. Elaborate. You can always repair a harness with a overlay and not replace the entire thing (expensive part and labor)
Yes, gladly. The common failure is the trunk open light remains on when the trunk is closed. However recently the video wire for my camera has broken too. So far I have repaired the trunk wire but I have not successfully repaired the video wire.
I did the first time it happened that is how I was able to fix my trunk light issue. Never the less, I still feel that the wire harness should not break. I am glad to hear that you have not experienced this issue perhaps I am part of a small group with this issue.
We had a Camry a decade ago that the wires that run along the trunk hinge broke because of the stress of repeated opening and closing of the trunk. Looked it up on the web and found it was extremely common on Camry's and a whole bunch of other cars too. Is that what's happened on yours?
This is a very common and very well known problem on XF Jaguars, and as mentioned it is caused by the constant flexing of the wires as the boot/trunk is opened and closed. Yes, you could argue it is a design flaw, and I have read elsewhere that it's partly due to the way the harness is secured at each end. I have also read that a little effort to relocate the harness securing points usually prevents the problem from reoccurring.
Disclaimer - despite owning two 2010 XFs for a number of years I never had this problem with either of them.
That was my first thought. If this is the case then it is a design flaw. If it's a design flaw I don't think that I should have to pay for the repair. If Jaguar can show me how my way of closing the trunk is causing this reoccurring wire breakage then I will gladly pay for the repair. Otherwise I think they should have a recall and fix their design flaw. Thanks for responding.
Recalls are for safety issues. This has nothing to do with safety.
Your cars is 8 years old and is long out of warranty. Older cars wear out and break. Forget factory support, irrespective of who made the car and what it cost when new.
Cost out: When a company pressures a supplier to reduce cost to increase profit margin, or supplier reduces quality of their product but believes it still meets design capabilitues to increase their profit margin. In eirher case there is risk associated with the cost out but in the end the customer is the one who suffers.
And the way the manufacturer looks at it, cars are designed for about a ten year useful life. The first owner is supposed to lease the car for one to two years and they'll bend over backwards to keep that owner happy enough to lease another one. The second owner is supposed to keep it to five years old and they MIGHT consider keeping that owner happy enough to come back and buy another lease return. After that, cars get wholesaled to a note lot and the car is fully expected and specifically designed to fall apart by ten years old (its called planned obsolescence). After all, they've got to be able to sell replacement cars in order to stay in business. If you drive yours past that, its by sheer luck or extraordinary maintenance but they couldn't care less about you because they don't stand to make a profit from you except maybe by selling the last few closeout parts to clear their shelves and make room for parts for the new models.
I too was disappointed by the quality of the wiring harnesses on my '07 XKR. I had read years ago about manufacturers using lighter gauge wire but was surprised to see so much unprotected wiring int he engine bay and under the chassis. While wrangling with my exhaust one of the hangers got tangled up in a bundle to tore two wires before I realized it. Not a horrible repair but every other car I've owned from '68 on has had better protection.
What I've found on hinges is to make the wire bundle twist vs. bend at the pivot point. Making a loop or changing what part of the harness flexes will relieve the stress on the wires.
Pretty much all OEMs are the same in this respect.
Jag may revise/improve parts as the model series progresses but minor stuff like a wiring harness would not be offered as a campaign.
I don't see people arguing it's minor but I do see people saying it's not a recall one.
At the age of most of the cars which are not suffering this, you'll need some luck to get anywhere.
Here, the wiring probably meets the sufficiently "durable" standard easily but I realise USA is very litigious (and I suppose that puts up the cost to car makers who pass it on in the price).
