IATs with Mina intake?
Old Apr 14, 2021 | 02:26 PM
Oxidizer2k's Avatar
Default IATs with Mina intake?
Recently installed my Mina intake and am wondering what my intake air temps are supposed to look like sitting versus moving. Anyone have any data on that?
Did two hard pulls from 30-70ish mph back to back and took a screen shot of my temps.
Pulled over and sat there for a little bit to see how high I can get the iat to go standing still.
Old Apr 14, 2021 | 03:44 PM
Sterling Smith's Avatar
Here is a video where they tested the Mina gallery intake on a dyno and tested the heat temps from a stock one.
Old Apr 14, 2021 | 04:18 PM
Oxidizer2k's Avatar
Need the info using the factory sensors to compare. They used external sensors.
Specifically I’m trying to figure out if my temps are within an acceptable range with the intake with the Florida heat.
Btw I’m in Orlando also.
Old Apr 14, 2021 | 04:38 PM
My intake temps are really high. I think they start around 95F like yours and go up to 147F when running the car hard. That is the reading from the ECU from my Torque app with my OBDII scanner. I am working on a better insulated intake/cooler system.
Old Apr 14, 2021 | 07:50 PM
Oxidizer2k's Avatar
For some reason torque always displays a lot higher. But that’s still info I can compare to. I’ll use torque and see what I get.
Old Apr 17, 2021 | 03:55 PM
Oxidizer2k's Avatar
Okay, so after some time with it on, I’m very impressed at how the car is doing. Sitting still the temps do go up. But moving it cools down pretty well. The car seems to be breathing a lot better. I’ll keep on testing and reporting back and it gets hotter outside.
Vytautas
Feb 21, 2025 05:25 PM
giandanielxk8
Jun 12, 2022 08:53 AM
Evan97
Oct 18, 2017 07:53 PM
bfsgross
119
May 19, 2013 09:38 PM
jsupstarz
Nov 29, 2012 07:20 PM
