Jaguar 2011 XF transmission faulty
Old Jul 28, 2014 | 06:34 AM
Pink Floyd's Avatar
Exclamation Jaguar 2011 XF transmission faulty
Hi, I have a 2011 XF 3.0 L petrol. 21000kms. Today as I was accelerating the engine revved up ,with the rpm touching 7k then a sign flashed "transmission failure "( it went away after a couple of minutes) but it was replaced by the check engine light. I tried switching the car off and on but the check engine light persists. The car is driving fine, I even used the flappy pedals for the gear shifts and shifting seems to have no problems. any insights? I am a new user here.
Old Jul 28, 2014 | 09:24 AM
nasa25's Avatar
Get the codes read and see what comes up
Might just be a random glitch, might be something more serious.
Old Jul 28, 2014 | 10:27 AM
Pink Floyd's Avatar
Default Thanks
That is what I am planning to do..but as it is rid here and everything is closed for the week...I guess I will just have to wait
Old Jul 28, 2014 | 10:34 AM
nasa25's Avatar
If I were you I'd get a cheap handheld scanner and read the codes yourself. Then clear the check engine light and make note of the codes.
If the issue reappears then take it in to get looked at
Old Jul 28, 2014 | 12:32 PM
Pink Floyd's Avatar
Thanks for the advice but I would have to order a scanner online and by the time it is delverd here..in Qatar hopefully eid holidays will be over..but I will order a scanner anyways will come in handy..thanks for the prompt reply though
Old Dec 10, 2014 | 05:05 AM
4sauto's Avatar
Hello,
We have a Client's XFR done just over 20000 Miles and the Cluster shows Transmission Fault.
When the vehicle is cold, it functions absolutely fine. After driving a few miles (15-20 miles) the transmission fault shows up.
The dealership has requested the client to change the entire Transmission. He is not happy with that and has requested us to look into the matter.
Any advice/suggestions on what I should be looking at?
Old Dec 10, 2014 | 12:39 PM
tbird6's Avatar
How does the fluid look?
Is it filled to the proper level?
Old Dec 10, 2014 | 08:25 PM
lotusespritse's Avatar
Originally Posted by 4sauto
Hello,
You're going to try to fix it, and you don't have a proper scanner to get the codes?
Good luck to that poor client.
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
plums
General Tech Help
Sep 1, 2015 06:34 AM
Dion Petty
Aug 30, 2015 01:00 PM
