Jaguar XF 2008 differential
Old Jan 19, 2019 | 04:05 PM
KevinEllik's Avatar
Default Jaguar XF 2008 differential
Hello.
Just bought myself an Jaguar XF 2008 2.7D 152kw.
Second day i heard some noises from rear side and it started about 70km/h.
Probably its my differential, and my question is: Does 3.0D 2009 differential fits to 2.7D 2008?
dont know so much about Jaguar's so i appreciate your help!
Old Jan 19, 2019 | 07:27 PM
lotusespritse's Avatar
Originally Posted by KevinEllik
Hello.
Start by changing the fluid. Get the factory fluid from the dealer. Save what comes out to examine it carefully.
If metal iis n the old fluid, you’re screwed and save the new fluid for a new diff. If fluid is ok, and new fluid fixes the noise, you’re golden.
Old Jan 23, 2019 | 11:13 AM
clubairth1's Avatar
Community Influencer
Any chance it could be a wheel bearing and not the differential?
Old Jan 31, 2019 | 01:20 PM
timfountain's Avatar
I thought I had a bad differential on my '09 XFSC and was really worried that it would cost $$$$'s to fix, considering that the diff is not readily available. Turns out I had a bad wheel bearing. $300 later and the car was back to her quiet, restrained self. Check wheel bearings first....
bfv01
Aug 19, 2014 08:40 PM
dreyco86
May 19, 2014 04:55 AM
magicjuan17
May 31, 2013 10:33 AM
Chromey35
Mar 20, 2013 02:13 PM
dd823
Oct 26, 2012 12:43 AM
