Jaguar XF battery drain.
Old Sep 29, 2019 | 06:41 AM
Jbdynamite's Avatar
Default Jaguar XF battery drain.
I have a Jaguar XF, and i had a battery drain problem. I noticed that the light was staying on in the instrimental key pad panel where you control the Temperature, Radio, GPS, etc. The light that shows the Jaguar emblem. That gets stuck on. I believe that that was causing the problem draining the Battery. When your car is turned off, make sure that the light is off there. It sometimes stays on....draining the battery. Hope that is the cause.
Old Oct 8, 2019 | 10:57 PM
B1G_LurK's Avatar
I am having the exact same problem and have no idea why.
Let me ask you: After a long drive, when you shut your car off, does it continue to make noise from the engine? Mine does....
Old Oct 9, 2019 | 12:11 AM
OzXFR's Avatar
This is a common Jag problem particularly on the F-Type.
The easiest fix is to reset the battery management system (BMS) by simply disconnecting the battery for a few minutes then reconnecting it.
Just trace the earth lead from the negative battery terminal to where it bolts to the floor of the boot/trunk and disconnect it at that end for a while, no need to muck about with the positive connection on the battery.
Give it a try, 10 minutes work, good chance it will do the trick.
If that doesn't work the battery could be on it's way out.
Old Oct 9, 2019 | 02:13 PM
clubairth1's Avatar
Community Influencer
It's also been reported that storing your keys too close to the car prevents it from going to sleep.
Can't say that's true as my keys are always stored about 10' from the car and I have not had any problems?
XFowner
Mar 29, 2020 03:20 AM
jaguarXFsupercharged_XFR 500HPclone
Mar 7, 2019 10:06 AM
2010XFR
Mar 28, 2018 09:02 AM
joneslau
Jul 19, 2016 10:41 AM
Craighead
Mar 8, 2015 09:31 PM
