Jaguar XF Horn Problem
Old Oct 1, 2014 | 07:49 AM
shaunsweb's Avatar
Default Jaguar XF Horn Problem
Hi all,
Firstly let me introduce myself. I'm shaun and a brand new member on the forum. I'm looking forward to reading the different threads and getting useful tips when working on my car.
I hope someone can help me. I have a 2008 Jaguar XF and whilst out driving at weekend, I realised the horn was not working. I got home and changed the fuse over but again no luck. Any ideas what the issue may be. This is my first issue with the car.
many thanks in advance for your assistance.
s
Old Oct 1, 2014 | 06:30 PM
Welcome to the forum Shaun,
I've moved your question from General Tech Help to X250 forum. Members here with the same model will be able to help.
________
Old Oct 2, 2014 | 07:01 PM
jaguny's Avatar
I can't offer help on the horn problem but welcome to the forum in the meantime!
Old Aug 12, 2024 | 05:43 AM
nuvolablue's Avatar
Hi, sorry to resurrect an old thread, but what was the resolution to this problem please @shaunsweb
Thanks.
Old Aug 12, 2024 | 07:49 AM
nuvolablue's Avatar
Hi. No idea why my thread isn't live, (say being moderated). Let me post here:
Trying to diagnose why my XFR horn is not working. Bought the car on weekend from a private seller; everything was fine on drive home. When I got home - horn started blaring.
Managed to remove fuse to stop it (Number 20 in engine bay for reference).
Next day i put fuse back in to try and diagnose issue. Now I have no horn at all.
Wondering if it is relay. Can anyone confirm if the below is the horn relay please ? Thanks.
Old Aug 13, 2024 | 05:27 AM
nuvolablue's Avatar
Any advice please on the Relay question ?
By the way, when I press the horn switch at the steering wheel, I can't hear any clicking on any of the relays in that fuse box, or elsewhere.
This suggests a problem at the switch end to me ? Any thoughts on my assumption ?
Planning to inspect the horns themselves today, to see if they are functioning by providing an (external) 12V power supply to them.
Thanks all.
Old Aug 13, 2024 | 08:14 AM
sportbrake_phil's Avatar
Thanks all.
Yes that is the horn relay.
Switch end ( including wiring and clock spring), or the relay has failed if the relay's not working. Check the feed voltage for the supply for the horns ( at the relay socket), and for the relay coil against a known good chassis "ground" point. If they're good, check the voltage of the other relay coil connection vs a know live feed, it should be grounded hence 12V difference whenever the horn button is pushed.
ELB3MD
Aug 12, 2024 05:41 AM
paul1156
Jun 6, 2018 01:15 PM
dokjonz71
Dec 15, 2016 11:44 AM
Jaytea
May 7, 2016 05:16 PM
blyth63
Apr 28, 2015 05:27 AM
