leaking coolant - infamous plastic water pump connector?
Hi All,
So the water pump and plastic tubes replacement weren't enough (pump with gaskets + AJ811539 + C2Z26930 + C2Z28258).
. Still coolant discharge in the front. I left the plastic connector in place and didn't touch the o-ring "inside" the connector tube.
Does anyone know if the connector tube comes with both o-rings - inside (to connect with engine) and outside (to connect pump)?
Do I have to buy an additional o-ring for the "inside" of the connector tube (part ID?)?
Any advice while replacing the connector (lube it or not?)?
Should I put any grase on the gaskets (red lithium rated at 300F)? One side or both sides of the gasket?
THanks!!!!
THanks!!!!
Juha Lystila
Jan 25, 2023 07:05 AM
BlackKat
Jan 27, 2019 09:07 PM
