leaking coolant - infamous plastic water pump connector?
Old Nov 28, 2021 | 08:02 PM
memento84's Avatar
Default leaking coolant - infamous plastic water pump connector?
Hi All,
So the water pump and plastic tubes replacement weren't enough (pump with gaskets + AJ811539 + C2Z26930 + C2Z28258).
. Still coolant discharge in the front. I left the plastic connector in place and didn't touch the o-ring "inside" the connector tube.
Does anyone know if the connector tube comes with both o-rings - inside (to connect with engine) and outside (to connect pump)?
Do I have to buy an additional o-ring for the "inside" of the connector tube (part ID?)?
Any advice while replacing the connector (lube it or not?)?
Should I put any grase on the gaskets (red lithium rated at 300F)? One side or both sides of the gasket?
THanks!!!!
Old Nov 30, 2021 | 03:30 PM
kansanbrit's Avatar
Connector tube only comes with one O Ring so you have to buy a second one. I lube with Vaseline. Gaskets don't need grease.
Old Nov 30, 2021 | 03:52 PM
memento84's Avatar
Hi,
Are they identical orings (in and outside tube one)? do You lube O rings on both, inside and outside?
Thanks!
Old Dec 1, 2021 | 08:35 AM
kansanbrit's Avatar
Yes identical, lube allover.
Old Dec 1, 2021 | 05:00 PM
memento84's Avatar
what is the correct torque for these bolts?
Thanks!!!
moe
Jul 19, 2025 09:52 AM
Juha Lystila
Jan 25, 2023 07:05 AM
BlackKat
Jan 27, 2019 09:07 PM
Kewpie
Feb 20, 2016 05:50 PM
Ravepolice
Jun 19, 2012 05:17 AM
