Light smoke from engine bay
Old Jun 22, 2015 | 02:09 AM
Catlan Zuliani's Avatar
Default Light smoke from engine bay
Fellow Jaguar owners, I am a new Jaguar owner and new to the page. Looking for suggestions. Tonight I was out cruising and dig racing with a group. I have the 5.0L V8 N/A. After 1.5hrs of going pretty hard, I stopped a light and noticed some smoking in the front that my headlamps illuminated. No warnings indicated on the dash. I pulled over, popped the hood, flashed my light and no smoke however I smelt coolant. I noticed some liquid on the skid plate, but no current/fresh leaks. Coolant level was down a tad, but was ok. Any ideas on what the smoke was from? I've driven it hard before and never an issue like this. Should I run my heater when I race to eliminate air pockets? Was it an air pocket that worked itself out on idle?
Any thoughts or ideas would be appreciated! Thanks folks.
Old Jun 22, 2015 | 05:01 AM
Bigg Will's Avatar
Your coolant level is going to be key, I'd keep an eye on it to see if the level drops much after it sits over night, a big drop might mean you have a leak. But honestly that haze or smoke you saw was probably from your brakes. Going hard means stopping hard.
Smelling coolant does not necessarily mean you have a leak.
Old Jun 23, 2015 | 01:56 AM
Today I pulled into the shop. I yanked the belly pan out to reveal if any leaks had occurred. There was some coolant there. And my coolant level was 2 inches below the min level line of the reservoir. The cap is holding pressure, the hoses/lines are just fine. There was burnt coolant under the oil pan, but no trace of where it came from! I started the engine, let it idle with the pressure cap off and heater full blast as it was bubbling on idle. I filled it up to min level to allow expansion when hot. The bubbling stopped. There is still a smell of coolant in the front of the engine block.
The smoke described beveled from the hood when I popped the hood that night, I doubt it was the brakes. I would of smelt brakes rather than coolant. This has completely floored me, almost like trying to remember a celebrities name from a certain movie and you should know it lol.
I will check the reservoir level in the morning and see if it is the same. Fingers are crossed
Old Jun 23, 2015 | 02:29 AM
Bigg Will's Avatar
Well the water pumps are notorious for failure on the 5.0 Jag.
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
TC Johnson
Sep 2, 2015 09:30 AM
