memory seat stopped working
Old Jan 27, 2013 | 06:38 AM
tigerwilsos's Avatar
Default memory seat stopped working
Hi
I have an XF 2009 and the memory settings buttons for the driver's seat has totally stopped working all of a sudden! I have tried to re-program it but nothing seems to work. Does anybody have any ideas of what I could do?
Tigerwilsos
Old Jan 27, 2013 | 10:43 AM
jagular's Avatar
If neither the seat nor the steering wheel and mirror adjustments work I suspect the switch or door connection in the harness. If some functions work but not others then the affected component or perhaps a central software glitch. A dealer is likely the only recourse for diagnosis.
Old Jan 28, 2013 | 07:18 AM
Jerry S's Avatar
Could be a blown fuse.
Old Jan 30, 2013 | 02:20 PM
Hi jerry s , I had considered the fuse but the problem has turned out to be intermi
ttent, on and off when it feels like ... Also the passenger Window opens on its own , again intermittent..
What do you think ......?
Old Jan 30, 2013 | 02:33 PM
[QUOTE=jagular;664740]If neither the seat nor the steering wheel and mirror adjustments work I suspect the switch or door connection in the harness. If some functions work but not others then the affected component or perhaps a central software glitch. A dealer is likely the only recourse for diagnosis
Hi thanks for the info , that does make sense as the problem is intermittent , going to put it on a diagnostic at the weekend ... Will let you know....
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
tberg
Sep 7, 2015 07:32 AM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
