Misfire, Misfire, Misfire! Or is it really a Misfire?
Old Aug 17, 2024 | 04:34 PM
KylefromBahamas's Avatar
Default Misfire, Misfire, Misfire! Or is it really a Misfire?
Hi Everyone ,
2012 Jaguar XF 5.0 Supercharge with about 90,000 miles.
I’ve been trying to solve a misfire for a year now. I’ve been experiencing misfire on random cylinders putting the car in restricted performance. Over this timeframe I have done the following:
1. Changed all 8 Spark Plugs, Injectors and Coils three times. - thinking each time it might just of been a bad batch.
2. Timing Chain. Thinking this is a Common issue so just got it done.
3. Both High Pressure Fuel Pumps. Thinking not enough fuel pressure to the banks.
4 Fuel Pump that’s located under the rear seat.
5. Change Engine and Transmission Mounts. Thinking it might be too much vibration due to bad mounts.
6. Removed catalytic converters (legal in Bahamas) thinking it might be clogged.
Now my friend and I went back at it again because there is a misfire on Cylinder 4 only. It was the injector which we changed. It ran really good for two 10 minute trips. On my third trip I got the restriction performance AGAIN! I scanned the car and now it’s misfire on cylinder 2! What the hell is doing on? Can someone please shed some light on this because it can’t be the injectors constantly needing to change but the thing is when I change the injectors that shows up bad on the obd scan the car rides like brand new for a few trips then another misfire.
Kindly take a look at the freeze frame of when the cyclinder 2 was detected, is it my battery? , is it the codes that says “faulty” in the photos below…. What possibly can be causing this?
Old Aug 18, 2024 | 12:13 PM
dennis black's Avatar
20 Year Member
One your injector seals may have failed on installing, even if it was new, make sure all injectors have the correct numbers, just to be sure , it could be fine but I would double check
Old Aug 18, 2024 | 12:31 PM
At this point I’ve installed new injectors over 3 times. And now C4 misfired I replaced that injector- it work fine then C2 is misfiring. Someone told me the stored code I have on the ECM is apart of a recall. I need a SDD software update and Calibration. Does anyone know if anyone is willing to come to bahamas to do this?
Old Aug 18, 2024 | 04:27 PM
20 Year Member
No all you need is a icarsoft v3 to clear jaguar codes ,very easy, you will have multiple misfires if even 1 injector is bad or not sealing
Old Aug 18, 2024 | 05:28 PM
Nice - I see I can get this icarsoft v3 from Amazon. Will the V3 come with the software I need to update and clear permanent stored codes? Because I have a permanent code stored on the ECM which is associated with the recall. (See link)
I’m almost quite certain it’s not the injectors. I’ve been constantly attacking them as my main concern all this time. Because what would happen is I’ll replace that injector which is misfiring - it’ll drive good for two or five trips then misfire on another cylinder.
Kindly see below ⬇️
https://f01.justanswer.com/EricFromC...fd3_recall.pdf
Old Aug 18, 2024 | 05:35 PM
Maybe even battery starting to go bad? @dennis black
Old Aug 18, 2024 | 07:48 PM
20 Year Member
It will come with a usb cord that hook into your computer and retrieve a updated version and register, now another solution is go to the dealer and ask them to remove all codes and test your battery, they should only charge you an hour, or do it yourself with the icarsoft
Make sure you order specific for Jaguar/Range rover
Old Aug 18, 2024 | 08:18 PM
20 Year Member
If you go to the dealer they will use SDD
Old Aug 19, 2024 | 01:11 PM
@dennis black thank you - the V3 will have all the updates already on it. I just need to plug and play?
thank you for all this.
Old Aug 19, 2024 | 10:57 PM
20 Year Member
Once you register your unit
Old Aug 28, 2024 | 05:39 PM
xalty's Avatar
if it happens under light load check your mafs
do not ask how i know
Old Sep 19, 2024 | 07:18 PM
Jssaab's Avatar
Yes new battery. THese cars have really high needs for voltage for the ignition system
HOw did you get the battery info on the display
Old Sep 20, 2024 | 06:55 PM
POD XF's Avatar
[QUOTE=KylefromBahamas;2777872
I’m almost quite certain it’s not the injectors. I’ve been constantly attacking them as my main concern all this time. Because what would happen is I’ll replace that injector which is misfiring - it’ll drive good for two or five trips then misfire on another cylinder.[/QUOTE]
Sounds to me like you have contamination in your fuel; you change the injector and the problem goes away, then comes back in another place, change that injector and the problem goes away, keeps randomly recurring at different injectors. Unless you're doing some other thing at the time you have replaced each injector.
Old Sep 23, 2024 | 03:25 PM
clubairth1's Avatar
Community Influencer
Many, many counterfeit parts.
Post pictures of the part number on the injectors. We have a number of threads on this.
Old Sep 23, 2024 | 10:53 PM
20 Year Member
Where did you purchase the injectors from and do you have part numbers
calvinG
Nov 8, 2023 11:52 PM
Darrol2004
Sep 2, 2022 09:23 AM
Jeffrey David Benson
Feb 9, 2022 11:31 AM
Winster69
Jul 9, 2017 08:34 AM
boliversmith
Jun 2, 2011 08:34 PM
