Most likely cause P0174
Old Mar 19, 2023 | 03:30 PM
kenc's Avatar
Ugh, OK it was a "red herring". I wondered if the smoke were coming from somewhere else, and just rolling down over the front of the motor, even though I couldn't see anything. Blew some compressed air over the top of the motor while running the smoke machine, and now there's a plume of smoke coming out the back of the motor and nothing from around the water pump area which makes sense.
Not looking forwards to pulling all this s**t off - never thought I'd have to do it again after the cooling pipe job.
Old Mar 19, 2023 | 04:16 PM
Gus's Avatar
Gus
See if this helps.
JagRepair.com - Jaguar Repair Information Resource
Old Mar 19, 2023 | 07:05 PM
kenc's Avatar
Originally Posted by Gus
Thanks, but unfortunately not. I wish it had been something as simple as the pcv valves. Too easy for me, it has to be something intake manifold related.
Old Mar 20, 2023 | 08:15 AM
clubairth1's Avatar
Community Influencer
I did see the smoke but I think your right? I can't tell either?
But if smoke is coming from the rear of the engine I don't see how that ties in with the intake system having an air leak?
Old Mar 20, 2023 | 06:01 PM
kenc's Avatar
It's only coming from the rear of the engine when I use low pressure compressed air blown over the top of the water pump area in order to determine if the smoke really was coming from that area or somehow "spilling over" from the under manifold area which it appears to be. Any smoke coming out of one of the manifold o-rings for example, will now be blown towards the back of the engine.
MintyJag
Apr 4, 2022 02:54 AM
Darealwoody
Oct 4, 2019 05:00 PM
GaiaXF-V8S
Jun 1, 2018 05:16 PM
cwindomsr
Nov 26, 2017 04:31 PM
raschwar
May 13, 2015 04:20 PM
