Multiple issues
Old Jan 4, 2020 | 02:33 PM
Schwop's Avatar
Default Multiple issues
Hello, I have a 2013 XF 3.0 AWD. Have only had it for a few months, today as i was driving, the audio, navigation, back up camera and bluetooth all stopped working. (back up didn't work when i got home but i assume it went of at same time as others).
is it a battery issue? a sofeware update issue?
rest of the car works fine...
any help appriciated
Old Jan 4, 2020 | 04:23 PM
davetibbs's Avatar
This implies a fault on a unit/module that is connected to the MOST network - so basically the things you've listed as not working. The most common of these to fail is the bluetooth module - maybe due to it's location, which is under the front left-hand seat (I believe), but it's the likely suspect. Have you tried disconnecting the battery to fully reset all the modules?
A way you can test this is to disconnect the fiberoptic cables to it and plug them into a loopback adaptor like this:
Amazon Amazon
, effectively taking the module out of the network.
Old Jan 4, 2020 | 04:32 PM
George05's Avatar
Jaguars are very bad for battery problems , that can lead to other electrical gremlins help your car by testing the battery and put it on charge over nite if need be
user 84302
Jan 29, 2025 05:04 PM
dsd
Jan 26, 2023 03:59 PM
ScubaAddict
Jan 27, 2022 07:59 PM
guppy710
Apr 2, 2016 02:12 PM
Point Man
Oct 13, 2008 06:02 PM
