is my dynamic mode and dsc working?
Old Aug 31, 2013 | 07:48 PM
BigD660's Avatar
Default is my dynamic mode and dsc working?
not sure if dynamic mode and traction control are working properly. when i turn on dynamic mode i feel no difference in suspension whatsoever. the button illuminates and dash icon turns on but i dont feel a difference. same with dsc. anyone else have this issue?
Old Sep 1, 2013 | 12:03 AM
10 XF Premium's Avatar
The dynamic mode sharpens the throttle response so you get a more head snapping off the line effect. Will cause you to lose a few MPG in the city.
The DSC mode is in three steps.
Fully on - normal mode, tire spin is almost not able to get. The stability mode is very active and will not let the car slide.
Hit button for a sec or two and it lights the dash light. It allows a very little bit of wheel spin.
Hold button down for 13 seconds and the dash light comes on and the center info system shows the DSC is fully off - smokes the tires, will not stop car from fish tailing.
Neither buttons give you more power, just removes the drivers aids to let you use gas faster and wear rear tires faster.
Old Sep 1, 2013 | 12:34 AM
Executive's Avatar
What year/model is your XF?
If you have '10 +SC variant, then Dynamic mode will enable CATS system - stiffer suspension.
In the NA car, the transmission will shift quicker and will make the throttle much more sensitive. No influence on the suspension
Old Sep 1, 2013 | 08:45 AM
BigD660's Avatar
it is a 2010 xfr 5L sc. does that mean what 10 xf p said does not apply or that is accurate?
Old Sep 1, 2013 | 09:20 AM
jaguny's Avatar
If the '10 is thevsame as the '11, you should feel the dynamic mode difference immediately, particularly if the road surface is uneven. If on smooth roads you may not feel it, however, I know the difference with mine instantly om my '11 SC. I don't like the feel of the car without it. Have you tried driving with and without on uneven road surfaces?
Old Sep 1, 2013 | 09:54 AM
What I said would only apply to the NA car.
the SC car has the adjustable suspension as Exec mentioned aboved.
Old Sep 1, 2013 | 11:22 AM
BigD660's Avatar
ok wow the traction control definitely works. thanks, nowi need new tires now lol. but the dynamic mode doesnt feel any different at all. i live on some back roads and im pretty sure i would tell a difference in the ride. what could that be?
Old Sep 1, 2013 | 02:39 PM
jaguny's Avatar
Not sure, I would have it checked out. The change with dynamic is noticeable.
Old Sep 1, 2013 | 09:19 PM
BigD660's Avatar
thanks yall
Old Sep 2, 2013 | 10:40 AM
RoswellJAG's Avatar
I too notice the difference in traction and gear behavior but not so much in the suspension. I've wondered myself if that part is working or effective.
Old Sep 2, 2013 | 03:23 PM
BigD660's Avatar
supposedly it tightens the springs for cornering but i measured from the tire to wheel well after turning it on and off of a flat surface and there was no difference. im definitely gonna look into it more.
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
cissdm
May 3, 2016 06:02 AM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
