My passenger window has stuck half way up
Old Aug 31, 2017 | 01:49 AM
normandinho's Avatar
Default My passenger window has stuck half way up
My 2010 XF has its passenger window stuck half way up and all garages are now closed. Is there anything I can do to close it for now. Also I'm not too sure how to get the door panel off. Thanks for any advice at all.
Old Aug 31, 2017 | 03:34 PM
TreVoRTasmin's Avatar
At least it is half way up not half way down. Did the motor simply stop, did it sound different? Did you try the switch on that side or just the master one on the drivers side? I'm assuming the others are working? I would still check for a possible fuse issue before getting too involved. You can always try a battery disconnect to see if the computers are just confused. Only time I ever had a window stop working was slowly over time.
Kief
Sep 6, 2017 01:43 AM
Serlock
Aug 16, 2017 11:02 PM
macdoesit
Aug 13, 2017 08:13 PM
Joe Gandalf
Aug 13, 2017 04:07 PM
Richard starkess
Aug 5, 2017 10:49 AM
