MY12 adding a Bluetooth module
Old Apr 2, 2019 | 06:03 AM
rftr666's Avatar
Default MY12 adding a Bluetooth module
Hi guys,
My friend just bought an XF MY12 with no bluetooth and he needs a handsfree. Is there a way to add it somehow? The car is a Premium Luxury 2.0 Turbo equipped with standard 10 speaker 400w sound system.
I did some research and I found that central unit has to be replaced which is costly, but I also found Audio2Car Adapter 84442 + two essential harnesses for about 100 euro. Supposedly it attaches to the amplifier on the left side of the boot.. Will that work?
Any help appreciated! Thanks!
Old Apr 3, 2019 | 06:28 PM
BritCars's Avatar
It should have Bluetooth for phone calls built in. If you want streaming audio which it doesn't do, either connect a 'Tune2Air' module (about $70) to the iPod connector in central arm rest if you have it and that will do steaming audio and control of tracks through steering wheel and track name display, or a usb BT streaming stick for nearly free which plugs into the usb in arm rest and streams audio but no controls
Depends a bit on which stereo system it has
sparkenzap
Nov 25, 2014 12:00 PM
the_dimwit
Mar 1, 2012 01:45 PM
WHealy
Jan 29, 2012 11:55 PM
VetteOwner
Aug 19, 2011 10:22 AM
rothe
Audio/Visual Electronics
Dec 5, 2010 03:38 PM
