New jag owner needs help ..2010 xf
Old Mar 13, 2017 | 07:36 PM
Sancho20's Avatar
Default New jag owner needs help ..2010 xf
Hi im a new owner have had my 2010 jag xf for about 2 months now and i love it except for today..i was driving and all then sudden i lost all power and pulled over to the side of the road..i tried starting it after this happened and it turned over like it was going to start but would not..i tried a couple more times and it would just keep turning over until i pressed the start button again..anyone experienced anything similar or have any ideas what might be causing this..thanks in advance for any suggestions
Old Mar 14, 2017 | 10:11 PM
BritCars's Avatar
Hi - sorry to hear that. Did it start eventually or is it still stuck? Any error codes or check engine light - you need a code reader to pull the codes
First two thoughts are battery issue (common cause of random issues - have it tested, cheap to replace). Or maybe fuel pump - a bit more of a hassle
Old Mar 14, 2017 | 10:28 PM
Sancho20's Avatar
Never got it started i have someone coming over tomorrow with a code reader..yea i was thinking fuel pump which i hope im wrong about ..one guy i talked swore it was a dying battery in my key fob which i didnt think it would be but i did buy a new battery for it anyways but that wasnt it..ill let you guys know what it is tomorrow if they are able to figure it out tomorrow morning..thanks
Old Mar 19, 2017 | 10:27 AM
Cherry_560sel's Avatar
did you put gas in it?
Old Mar 19, 2017 | 10:29 AM
Sancho20's Avatar
No , but it already had gas in it..
Old Mar 20, 2017 | 01:14 AM
Hang in there dude....let the forum know what codes come up and go from there. Any chance you purchased an extended warranty when you bought the car?
There are a few posts from members who have experienced something similar. Drill down through the posts and you will find a post that is related to your issue. Bad fuel pump seems to be the common variable that fits the issue you are having
Old Mar 20, 2017 | 01:18 AM
Sancho20's Avatar
Well i had my mechanic look at it and run codes and apparently there is a recall on the ecm for a software update related to the fuel pump but when i called the dealership he said it had nothing to do with the fuel pump ..but my problem is my car wont start so i have no way to get it to the dealership ..
Old Mar 20, 2017 | 01:19 AM
tow it there???
Old Mar 20, 2017 | 01:21 AM
Sancho20's Avatar
Yea i guess thats my only option since i dont know why the guy at the dealership is telling me it has nothing to do with the fuel pump when the recall says ecm software update for fuel pump failure..
Old Mar 20, 2017 | 01:32 AM
Like i said...research the forum...find common variables that cause the issue you are having, then go from there. Good luck
Old Mar 20, 2017 | 01:54 AM
OzXFR's Avatar
Maybe the guy at the dealership is just being pedantic, in that it might be a software problem only and no mechanical problem with the fuel pump?
Old Mar 20, 2017 | 05:50 PM
Sancho20's Avatar
Yea it kind of seemed like he wasnt that interested in helping me..but i talked to my mechanic and the code he got was p0627
Old Mar 20, 2017 | 07:51 PM
Understand that the service advisors are not going to diagnose your problem or give you any sort of advice.
They only need to know if you are under warranty or paying for the repairs yourself. They can do tell you the service history of the car and that is about it. There are lots of certified techs that hang out in here...someone will let you know what that code refers to.
Old Mar 20, 2017 | 07:55 PM
Sancho20's Avatar
I understand that but i just called to get my recall performed and he insisted it had nothing to do with the fuel pump but the recall clearly says that the recall involves the fuel pump
Old Mar 20, 2017 | 08:01 PM
ok. fine. are they taking the car in? If you are in a 2011, that means it is out of factory warranty...recall or no recall, they aren't going to take your car in and fix whatever is wrong with it for free. You are going to have to pay them for the work they do. They will address the software update after your car is running. What exactly do you expect them to do?
If my car had gone out of warranty ...I would be purchasing an extended warranty. You might want to think bout that.
Old Mar 20, 2017 | 08:03 PM
Sancho20's Avatar
I was under the impression that if there is a recall they perform the work for free . .I just expect them to do the software update on the ecm as the recall states..
Old Mar 20, 2017 | 10:01 PM
Ok...but think this through. You want to take a non starting car into a.Jaguar dealership and have them reflash the ecu. Then what? You will get the.same nonstarting car back? It accomplishes nothing. Get.the.car running first.
Old Mar 20, 2017 | 10:06 PM
Sancho20's Avatar
Well obviously im hoping them reflashing the ecm will fix my problem thats why i would be taking the car there..my mechanic said i should do this before i start fixing things like the fuel pump that could be over $1000 to fix..
Old Mar 20, 2017 | 10:39 PM
good luck man.
Old Mar 21, 2017 | 11:36 AM
geekonaleash's Avatar
I would go with BritCars initial suggestion and battery first. When my battery went too flat for the car, similar issue to yours occurred. Note the battery might not be flat, but if the XF detects it is below a certain level it will not start and either need charging or replacing.
It is the heaper and quick fix option (if it works) and no harm having a spare battery just in case (I now always keep the spare battery topped up and if the other starts to dip swap and charge.
Hope you sort the issue soon.
Dave
