Oil levels
Old Apr 3, 2014 | 02:02 PM
Maz's Avatar
Maz
Default Oil levels
My jag xf oil level is 3/4 full ...should I top this up now ?
Old Apr 3, 2014 | 02:19 PM
jagular's Avatar
No.
If you are relying on the dipstick then 3/4 is ample. If yours has the electronic oil level display it tells you when you need to add oil.
A sump full to the "max" mark is no longer important because oil consumption is very low.
At 3/4 you still have more than 6 litres of oil in a 4.2 and even more in a 5.0 or 3.0 SCV6.
Old Apr 3, 2014 | 02:39 PM
If there are no leaks, you don't use maximum performance to go everywhere or do a lot of short runs, the level shouldn't drop from Max down to Min between scheduled oil changes.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
duecedriver
Dec 25, 2015 11:47 AM
mrplow58
Sep 15, 2015 09:58 PM
tonyforman
Sep 10, 2015 07:23 PM
