problem after new battery
Old Sep 10, 2021 | 04:53 PM
Richard Zuniga's Avatar
Default problem after new battery
well not really after new battery install been happening for a couple days
checked battery and yes voltage waa low so got a new one
now this hasn't gone away... didn't think it was the starter until now..
thoughts/opinions..
thanks
(hoping it's not the starter)
Old Sep 10, 2021 | 04:55 PM
vid
https://streamable.com/xoo67y
Old Sep 10, 2021 | 05:31 PM
John Williams's Avatar
When you replace a battery you will need to reset the BMS or else the car will not know a new battery has been fitted!
The BMS will eventually do a self-reset & the charging rate will adapt to the new battery!
Old Sep 10, 2021 | 05:46 PM
cool
easy procedure?
not in car right now got scared it would've left me somewhere
so doing that would possibly clear up that noise and reset the sysyem??
Old Sep 10, 2021 | 09:00 PM
BritCars's Avatar
Definitely sounds like low battery. But BMS reset prob not going to fix that. You need to charge battery.
Measure battery voltage with engine off - what does it measure? You need to fully charge up the battery with a charger or on a long drive. And then test to ensure the alternator is working to keep it charged once running
You are 'technically' meant to reset bms but it will catch up by itself and I've never reset it myself in 10 years and a few battery changes and not had any issues
Old Sep 10, 2021 | 09:10 PM
well I did change the battery right before that video
yea the volts were low when they put the machine to check it
so now I'm like wtf
Im hoping it's not the starter
Old Sep 12, 2021 | 09:04 AM
any idea on the reset procedure?
I Google and it said sonething about putting in some radio code and the parking brake and windows
the brake and windows didn't change as the auto place put a memory saver thing on the obd port
thanks yall
Old Sep 12, 2021 | 08:46 PM
BritCars's Avatar
Some basic info on BMS here
http://www.londonroadgarage.com/imag...monitoring.pdf
You need a code reader tool with Jag specific functionality to reset it. I have the icarsoft LRII and I've read that it does BMS reset (I've never bothered - it recalibrates itself over time anyway)
Old Sep 12, 2021 | 08:49 PM
ah it resets/recalibrates itself
ok good to know
seems like that noise in the video is slowly going away and it's starting a but faster now maybe thats it...glad otlr at least it gives me hope that it's not the starter
ty for the info yall
Mikehill596
Jan 15, 2022 11:09 AM
TreVoRTasmin
Dec 23, 2020 04:50 PM
Darrenmb
Nov 15, 2014 01:42 PM
hillbilly20
Mar 2, 2013 03:22 PM
XTypeJagMan
Jan 30, 2012 09:41 AM
