problem changing spark plugs
Old May 8, 2023 | 09:01 AM
iownme's Avatar
Default problem changing spark plugs
im doing the passenger side bank (U.S)
eventually got that rubber shield out....what a pain.
disconnected all the vacuum and coolant lines.
unplugged the coil plugs.
disconnected the 4 wiring loom connectors at the front of the engine.
unclipped the 3 clips to move the wiring loom out of the way.
now is where the problem is, i cant move the wiring loom because
i think i need to remove the 3 injector wiring plugs, but they look very difficult to get to, and even more difficult to re-attach if im even able to get them off.
anyone run into this?....any advice on how to proceed?.... id hate to give up at this point but i also dont want to end up with a disabled car in the driveway, i already got the drivers side done.
Old May 8, 2023 | 10:18 AM
pab's Avatar
pab
Knowing all that is why I paid the dealer $1000 to change the 6 plugs on my car ... ;-)
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old May 8, 2023 | 11:41 AM
iownme's Avatar
thats all well and good but not all jaguar owners have jaguar wallets which is kinda the purpose of these various forums 😜
Old May 8, 2023 | 03:17 PM
iownme's Avatar
turned out it was really easy to do the passenger side, just had to remove a few bolts and other pieces and had full access to all 3 coils...i'll make a separate thread as there is not any on the internet which deal with this engine in this body....
the XF, XE and F type share an engine but the videos showing XE and F type are different and much easier than the XF.
PAB.... let me know when you next need them done, i'll only charge $750😜😜😂😂
Old May 8, 2023 | 03:23 PM
iownme's Avatar
look at all that room!
Old May 9, 2023 | 09:16 PM
lotusespritse's Avatar
It's super easy to change plugs on a Range Rover Sport with the same engine. I could never get it done on the XF.
Old May 10, 2023 | 07:01 AM
iownme's Avatar
its laughably easy considering every post says its impossible, i could likely do it in 30 minutes now
Old May 10, 2023 | 10:50 AM
pab's Avatar
pab
DEAL!!
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old May 10, 2023 | 08:56 PM
You can change all the plugs in 30 mins on the XF now? It so, that’s impressive.
Old May 11, 2023 | 10:53 AM
iownme's Avatar
lets be fair now...30 minutes per side!
passenger side is now the easier side!
Old May 11, 2023 | 11:01 AM
iownme's Avatar
removing this piece is the key....it looks like a lot of work but it only involves removing 8 easy to access 10mm bolts.
(and 3 of those are the fuse box bolts which allows you to swing that out of the way too)
the benefit of this is method is the rubber/foam piece which is normally difficult to install, is really easy and just pops in place
Remnant1
Dec 21, 2022 06:52 AM
Stu II
Aug 1, 2018 02:08 AM
seagates5
Apr 9, 2015 05:23 PM
Countriboi03
Aug 3, 2013 04:10 PM
