Rear Upper Control Arm spinning nut Nightmare
Old Jun 28, 2025 | 11:20 AM
JamBar's Avatar
Default Rear Upper Control Arm spinning nut Nightmare
Hi
Got a 2008/9 XF Portfolio 5.0 NA.
Needs a new rear passenger side upper control arm which we have.
Front bolt removed.
How to stop the nut spinning on the rear bolt?
Crows foot does not hold it, it stops spinning but will not rotate at all. Tried impact wrench, but just shakes it all lose and tools at back come off despite being jammed.
There is no tab on the nut as suggested in some forums.
The nut is not welded in, as suggested in some forums.
No room at all to get anything in there.
Gallon of petrol and a match is nearing............
Any thoughts? How to remove this?
Old Jun 29, 2025 | 08:03 AM
JamBar's Avatar
Dear moderators, thanks for moving my post.
Ref the problem itself........... Any thoughts?
I am thinking of having to take the rear strut out to get to it.
Thanks in advance.
Old Jun 29, 2025 | 09:04 AM
bydand's Avatar
Default I can't get my Nuts Off!
Originally Posted by JamBar
Hi
Front bolt removed.
"No room at all to get anything in there?"
Try harder! are you using a 3/8 socket set, and or ring spanners. Tools for the job.
Are you using the correct size sockets? Do you expect/are both sides the same size??
If you can get your hands on it you can get it off with the correct sized tools.
Man up and pull yourself together.
Using the correct tools, Socket size, depth (deep), small extension, Tommy bar, small ratchet, and or small ring spanner etc,etc. There is room to secure the nut and slacken off.
Managed it on the S type, XF and the XK.
For King and Country, England expects! Removal.
Old Jun 29, 2025 | 12:26 PM
JamBar's Avatar
Done.
topanga
Jun 1, 2022 03:11 PM
cooldood
Feb 8, 2022 05:27 PM
Dell Gailey
Jun 20, 2021 11:04 AM
Jon89
Nov 17, 2017 07:55 AM
