Rear wheel bearings
Old Dec 14, 2021 | 09:52 AM
Dmcr's Avatar
Default Rear wheel bearings
How many bearings are there per side in the rear wheel hubs.
Old Dec 14, 2021 | 02:36 PM
chris.schneider's Avatar
One bearing set per side. Hard to replace, needs a lot of force. 10ton will not do.
Chris
Old Dec 14, 2021 | 02:46 PM
Dmcr's Avatar
Chris
thanks. I should maybe re phrase . is there one bearing on the left wheel and one on the right wheel or 2 per wheel
Old Dec 14, 2021 | 02:51 PM
Well yes, technically there are two bearings per side, as with any wheel bearing. But they are combined in one bearing set, which can only be replaced as an entire assembly.
Hope that clarifies
Chris
Old Dec 14, 2021 | 02:54 PM
Dmcr's Avatar
Hope that clarifies
Chris
ah ok no worries. I couldn't seem to find the entire assembly for sale anywhere. For the rear the only kit available is the bearing itself.
Old Dec 14, 2021 | 03:06 PM
Dmcr's Avatar
only seems to be 1 bearing per hub. Item no. 11 in the photo
Old Dec 15, 2021 | 01:34 AM
Thats what I keep saying.
Chris
Old Dec 15, 2021 | 02:48 AM
Dmcr's Avatar
Chris
Do you think a good garage mechanic with all the tools and a bearing press/puller should be able to extract the old bearing and put in a new one
Old Dec 15, 2021 | 02:57 AM
Yes, if they have a good press with at least 20tons.
Here are some details:
https://www.jaguarforums.com/forum/x...p-step-251225/
Chris
Old Dec 15, 2021 | 03:29 AM
Dmcr's Avatar
Chris
Thanks.. That's brilliant. So helpful. Scary amount of tonnage needed to do the job. 😲
Jaguarstyper
Jun 19, 2019 07:55 PM
awil
Sep 30, 2013 01:27 AM
matjohns
Oct 25, 2010 04:27 AM
