Replace Gas / Fuel Cap
Old Jun 12, 2018 | 08:51 AM
tapau's Avatar
Default Replace Gas / Fuel Cap
The rubber holder that connects the gas cap to the door has broken and I want to replace it. Just need to know what's connecting it to the door. Is that a rivet? Do I need to drill it out?
Old Jun 12, 2018 | 10:48 AM
maverickhx's Avatar
Why is your Gas cap yellow? Can the XF actually take E85?
No, it's not a rivet, just yank it out (The whole rubber part there). Believe it or not, using an old fork might help you if you slide it under so that the little push pin is between the teeth of the fork.
Old Jun 13, 2018 | 07:46 AM
tapau's Avatar
I have a 2014 XF 3.0 and yes, my car can use E85, but I don't.
Old Jun 14, 2018 | 07:34 AM
Tdsr's Avatar
The round bit you can see is a plug. You can lever the whole thing off with a small flathead screwdriver. Don’t damage the plug as the replacement fuel cap doesn’t have it. I’ve attached a pic of the part after you remove it
Attached Thumbnails Replace Gas / Fuel Cap-a96ff04a-8525-4854-bfce-7065c16e5c2d.png
jimlombardi
May 9, 2019 08:17 AM
1964Daimler
Sep 8, 2015 11:54 PM
lastgoodbye
Dec 16, 2013 11:03 AM
alyree
Dec 15, 2011 04:32 PM
chriscowan
Jan 1, 2010 10:32 AM
