replacing the battery in my 2012 XF
Old Jan 27, 2016 | 06:38 PM
  #41
DPK's Avatar
DPK
You are very welcome...
Old Dec 20, 2019 | 01:19 PM
  #42
tlcarman's Avatar
Lightbulb Recalibration following a battery change?
Originally Posted by 10 XF Premium
If your car is like my old 2010 Premium Lux. then after you reconnect the battery you will need to calibrate the parking brakes and all the windows.
The windows are simple: Press and hold the window down button until the window is all the way down AND you hear a faint "Click" inside the door. Then hold the switch up and do the exact same thing, let it close and hold it until you hear a click. This is to relearn the auto up/down features. It may require you to do it a few times if it does not take the first time. Do that for each door.
The parking brake is not too much different. With the car running, in park, hold down the foot brake pedal and apply the electronic brake (you will feel the pedal go further down under your foot). Then release the electric brake. Repeat that process for 3 or 4 times and it should be good.
That's it.
I have never actually replaced my battery but have disconnected it several times for brake service and terminal cleaning.
I heard of a different method when installing a battery in an XF or any modern car that requires re-calibration. If you have the new battery in hand and have the car running, leave the engine running, disconnect the old battery , install the new and your done. Essentially the same technique as using a battery tender hooked up while you install the new battery only there is no threat of having the battery charge spiking in voltage. Leaving the engine running worked great for me and I didn't have to reset or re-calibrate anything.
Old Dec 20, 2019 | 02:05 PM
  #43
JagV8's Avatar
It's best never to disconnect the battery with the engine running as the car needs it to prevent over-voltage/spikes from the alternator.
Sounds like you were lucky.
Old Apr 21, 2025 | 08:18 AM
  #44
famfirst's Avatar
That's it.
Hi,
Is there a way to reset my door locks? they stopped working after I changed my battery this weekend. Thank you for your time.
scotsgeeza
Dec 22, 2020 07:12 AM
BigCat09
Dec 4, 2019 03:06 PM
SunFlower
Oct 14, 2019 09:44 PM
jaguarXFsupercharged_XFR 500HPclone
Mar 7, 2019 10:06 AM
leadfoot4
Mar 20, 2018 09:24 PM
