Rim offset
Old Mar 25, 2019 | 08:59 PM
garysaunders85's Avatar
Default Rim offset
I have a 2010 XF with 19 inch rims. I see that factory has a 49 mm offset. Does my new rims have to be at 49 mm offset as well or can I go with different sizes that are somewhat close?
Old Mar 26, 2019 | 07:10 AM
mrNewt's Avatar
What other offsets are you considering? You want to go wider?
Old Mar 26, 2019 | 08:18 AM
I'm still looking at the 19x8.5. The offset on the rims I want are 44 mm instead of 49 mm. I've also seen some that were mid 30 mm that I like.
Old Mar 26, 2019 | 09:27 AM
mrNewt's Avatar
You should be OK with 44mm - mind 30s might be OK as well, depending on the tire you plan to run - how wide is going to be and the type of the thread.
Also, make sure that the side wall on the tire is not too tall - keep it at most stock height (which I think is 35!?!?).
iownme
May 27, 2020 07:37 AM
mrathell
Jun 5, 2017 01:56 PM
vincent661983
Jul 28, 2014 12:43 PM
edtexas
Jul 22, 2011 08:37 AM
racaz
Nov 30, 2007 11:26 AM
