secondary air injection pump
Old Sep 22, 2025 | 02:51 PM
jakesdad's Avatar
Default secondary air injection pump
on a 2009 XF 4.2 NA premium luxury, how can i test the secondary air injection pump itself to see if it is operating. lately i've started getting cel with codes 0411 and 0491. A long time ago i got these codes but they turned off and cel turned off without reset, but now the cel comes on with these codes consistently.
2nd dumb question.....I found a 2-wire plug laying on garage floor in the area where I generally work on my cars. But it does not have any wires on it and where there would be wires, it appears to be sealed with green rubber, like a dummy plug. Are there "dummy plugs" on a 2009 XF for some reason and this mystery plug is leaving a circuit open?
Old Sep 22, 2025 | 07:39 PM
POD XF's Avatar
To your 2nd question, there will be some 'dummy' plugs, particularly as you have the na car and the main loom is probably common with the sc version, however if there are no loops of wire on the dummy plug, it serves no purpose other than weatherproofing the unused part of the loom. There are probably other dummy plugs on your car that have a wire loop from one terminal to another, losing these will likely cause problems but a totally blank one is just a weather cap. You might get gremlins though if water gets into the unprotected place where it came from.
Old Sep 23, 2025 | 09:49 AM
clubairth1's Avatar
Community Influencer
A picture or two would also help with that plug?
It's pointing to the secondary air injection pump. Is it working? I would find where it is on your engine and start with some inspections to see if anything looks wrong.
Old Sep 24, 2025 | 10:24 AM
jakesdad's Avatar
How can I tell if pump is working? With car running, I can't hear or feel anything other than the engine running. Here are pics of the mystery plug. And btw, not certain the plug is from this car. I have 3 cars that have recently been on stands and worked on in the same spot in garage.
Old Sep 24, 2025 | 12:45 PM
jakesdad's Avatar
update....I did remove the headlight for good view of secondary air pump and started engine. Put my hand on pump...it is running for a short duration 20 seconds or less. what's next in line to check? all the hoses and lines appear to be in tact.
Old Sep 25, 2025 | 10:05 AM
clubairth1's Avatar
Maybe get another pump? Your car is old and the plastic is decayed by now.
I would disconnect the pump to see if you get different error codes.
You have to let the car guide you to what's wrong by following the codes.
Always00
Jun 23, 2024 06:47 AM
blaydes99
Dec 29, 2020 04:36 PM
Rivguy
Sep 25, 2020 11:35 PM
Loveman22
Feb 6, 2017 08:57 AM
AlbBolivar
Mar 26, 2016 10:21 PM
