Side Mirror Housing removal XF 2011
Old Apr 2, 2016 | 03:21 AM
MarkC123's Avatar
Default Side Mirror Housing removal XF 2011
Hi all
I wonder if you could help I need to remove a broken mirror housing off my car. I have found plenty of info on removing mirror and door cards but not how to remove the side mirror housing. Has anyone had any experience with this? or know of a resource they could point me towards?
Old Apr 2, 2016 | 04:48 AM
Welcome to the forum Mark,
I've moved your question from UK & Eire Region to X250 forum. Members here with the same model will be able to help.
Old Apr 2, 2016 | 05:05 AM
Mark,
Do you want to remove the Back Cover (item 1) or the complete door mirror assembly?
The assembly is secured with three M6 x 16mm hex screws which will be accessible from inside the vehicle.
Over to members with XF's to tell you how to remove the necessary trim items.
Old Apr 2, 2016 | 07:47 AM
MarkC123's Avatar
Thank you
I am still figuring out what is possible. The main housing is broken beyond repair and the LED light assembly is damaged. all the other internals are still working correctly, such as folding motor and dimmer for night driving. Essentially all I need to replace is the main housing, the top cover and the LED light strip. I am currently assuming to achieve this I would need to remove the whole lot from the door.
Thank you
Old Apr 2, 2016 | 07:51 AM
MarkC123's Avatar
another point
Referring to your diagram; I need parts 1 and 2 and the LED strip which isn't itemised in you diagram.
mikefarnham
Apr 4, 2026 04:12 AM
hisport
Apr 3, 2016 07:34 PM
Alan Stoldt
Apr 1, 2016 02:49 PM
Asdrewq
Mar 31, 2016 06:50 PM
razorboy
Mar 29, 2016 01:08 PM
