small cloud of blue smoke ?
Old Aug 28, 2020 | 09:21 AM
gary vosper's Avatar
Default small cloud of blue smoke ?
Hi peeps,
dont know if i have a problem or no, under hard acceleration no smoke but when gear box changes up (both on auto and tiptronic) there is a small cloud of blue smoke, also the same on kick down under hard acceleration. Also had my window down one time while accelerating and heard a small hiss like sound like a very quiet dump valve sound just before auto gear change, just wondering if that was normal as well, sry if these seem silly questions but this is my first jag (and loving it) and never had a turbo car before now,
thanking peeps in advance for any replies
Gary
2009 xf 3.0L Lux S
Old Aug 28, 2020 | 01:13 PM
clubairth1's Avatar
Community Influencer
No sure but does the car use any oil? The smoke puffs might be so small that your not consuming much if any oil?
Since yours is a 2009 how many miles does it have? Might not have gotten regular oil changes before you got it too.
Old Aug 28, 2020 | 02:08 PM
Hi clubairth1,
when i say small cloud it is noticeable but not plumes of it, i would say yes it does use oil but no more than any other cars that i have owned, there is 90,000 on the clock and has fsh
Old Aug 28, 2020 | 04:11 PM
clubairth1's Avatar
What oil are you running? Changed when?
Might try some of the high mileage oils instead.
It could be normal too. But at 90K you really should not be using any oil.
Old Aug 29, 2020 | 03:40 AM
Hi I have put in Castrol magnatec 5w 30 c2 less than 500mm from march 2020 when i bought the car, dont know what oil was used on service just before i took delivery of the car,also no smoke on first start up or any start up, what high mileage oil would you recommend, sorry to be a pain but is that small hiss sound just before a gear change under hard acceleration just a normal "dump valve" noise ? like i said before first jag so all this is new to me but really do appreciate you taking time out to help
Old Aug 29, 2020 | 11:02 AM
clubairth1's Avatar
Unless you have an error code I would not worry about the hiss. Have you run the codes and erased them?
I don't really know if high mileage engine oils are anything special or not. My recommendation is to run the oil called for by Jaguar.
You don't have a dump valve so not sure what the hiss could be.
Old Aug 29, 2020 | 12:29 PM
hi clubairth1
no error codes so thats all good, will do an oil change and put in the specified oil and see if that improves the smoke, and thanks for letting me know i dont have a dump valve (newbee or what !!!) thought all turbo's had dump valves
thanks mate for all your help, much appreciated
Old Aug 31, 2020 | 09:11 AM
Jssaab's Avatar
It's a Diesel
Old Aug 31, 2020 | 10:52 AM
kenc's Avatar
Originally Posted by Jssaab
It's a Diesel
True, don't all Diesel's smoke?
Old Aug 31, 2020 | 12:59 PM
sorry guy's like i said before my first jag (and loving it) so all this is new to me also first diesel and first turbo
Old Aug 31, 2020 | 04:11 PM
davetibbs's Avatar
Yeah, a small cloud of particulate on hard accleration/gear change is pretty common on diesels - especially if a large amount of time spent idling/low revs around town.
Give it an Italian tune up and see if the smoke puffs decrease/disappear.
Old Aug 31, 2020 | 06:43 PM
User 42324's Avatar
Originally Posted by gary vosper
Hi I have put in Castrol magnatec 5w 30 c2 less than 500mm from march 2020 when i bought the car . . .
You should be using ACEA C1 low SAPS oil in your diesel. You may get away with C3 but should not be using C2.
C1 0.5% ash
C2 0.8% ash
C3 <0.8% ash
C2 & C3 are rated as mid-SAPS, C1 is rated as low SAPS
Old Aug 31, 2020 | 06:55 PM
User 42324's Avatar
Not when fitted with a DPF.
Old Sep 1, 2020 | 05:01 AM
cheers robinus, that info was invaluable about the type, i also looked it up this morning before i saw your post and what you said is spot on so ty for that, could it be that the c2 oil was causing the smoke ??, could also be that the garage also put in a c2 5w30 oil when doing the service before i picked the car up last march, but anyway not too bothered since i got my mate to put on the error code checker and none came up, will deffo do an oil change over the weekend and see if that makes any difference, thanks again for your input much appreciated
Old Sep 1, 2020 | 06:28 AM
User 42324's Avatar
Who knows what the garage put in but I don't think it's likely that the oil is the source of the smoke. Yes, blue smoke is usually oil but it's not appearing on full throttle, only gear changes. Hmmm . . .
Pop on over to the UK based site www.jaguarforum.com where the XF sold was primarily diesel. This is the US based site & the diesel was never sold in that market.
Old Sep 1, 2020 | 07:34 AM
Bigv's Avatar
If there’s blue smoke, it’s burning oil
Old Sep 1, 2020 | 08:14 AM
User 42324's Avatar
I wasn't quite clear it seems. I don't think the ACEA class of your oil will give you blue smoke (but it will fill up your DPF quicker). The blue smoke in your exhaust is caused by oil being burnt. Keep an eye on your oil level.
Old Sep 1, 2020 | 01:28 PM
well a BIG THANK YOU to everyone who has taken the trouble to advise me and will now bother fellow jag owners on the uk site,
(proper newbee me, not knowing this was a us site) if I dont have a sat nav i get lost quite easily
cheers guy's
Ajohnsonnefn
Jun 18, 2023 02:45 AM
Paul Hutchinson
Nov 25, 2019 06:05 AM
SkipM
Jun 21, 2011 01:49 PM
cpm53
May 1, 2011 06:09 AM
jxnslotcar
Apr 23, 2008 04:38 PM
