Squeaky suspension
Old Feb 15, 2019 | 03:45 PM
Dj5ivestar's Avatar
Default Squeaky suspension
09 jaguar xf squeaky suspension issue.
looked underneath the vehicle discovered rear bushing are worn.
Can i just replace bushings or would i need to buy new suspension parts.
Old Feb 15, 2019 | 03:49 PM
davetibbs's Avatar
Depends on which rear bushing! But most of them can be replaced. Consider Powerflex bushings if you're going to the effort of replacing them. The service manual mentions lots of different special tools for the bushings around the car but most of the time these just refer to the different sized inserts to press them out - so long as you have access to a hydraulic press (you'll be needing one) with a decent range of insert sizes you should be fine.
Old Feb 20, 2019 | 04:53 AM
mermade's Avatar
There are a few bushes on the back end and would also recommend powerflex bushes as they have a lifetime guarantee
Old Feb 23, 2019 | 08:34 AM
Dean McCallum's Avatar
i need number 11 doing on this diagram. any idea how much a local gargage will charge for doing this if i get the part myself?
Old Feb 23, 2019 | 10:02 AM
Taffster's Avatar
Hmm, when I go over my driveway apron I hear a creak and groan or two. I have a 2014 XFR-S with just over 25,000 miles on it, and the last service/inspection (one month ago), everything checked out.
Patrick Kelly
May 19, 2016 12:04 PM
04xtype04
Mar 9, 2014 05:34 PM
310jag
Apr 1, 2013 01:44 PM
barley
Jul 20, 2012 06:20 AM
RRT
Feb 7, 2012 06:01 AM
