Stuck Accelerator Pedal While Driving in a '12 XFR...
Old Jul 7, 2024 | 11:55 AM
JagV8's Avatar
You need a mechanic with a clue!!
There's not many faults it can be, air leak, sticking throttle plate, whatever. Happens to lots of cars. The older they get the more troubles.
Old Jul 8, 2024 | 04:04 AM
Per's Avatar
Per
Originally Posted by MoscowLeaper
Jaguar diesels have a throttle, which should stop an engine in case of a over-rev.
Put in neutral, DO NOT switch an ignition off and the throttle will be closed (w/o an air supply the diesel will stop). If you turn the ignition off the engine will be destroyed.
NEighbour with the same engine in an X350 did just that, engine still went bang. Turned out an apprentice had filled new oil to max. The engine will overrev when selfdieseling, it was initially doing that even before he hit the brakes and switched to neutral. Btw he is an autoelectrician at my specialist and well aware of the problem. And a very calm guy, never seen him stressed or agitated in twenty years. So something not in accord with your statement here.
Specialist I use (only Jag and LR) had on one occasion three! LR engines on pallets from same self destruction. Owners had been sloppy woth servicing.
Old Jul 8, 2024 | 11:01 AM
JagV8's Avatar
Latest posts are for the 5.0 & gas (petrol).
JagBrian
Aug 18, 2019 05:07 PM
ajacks86
Oct 12, 2017 08:51 PM
Rlover
Mar 30, 2016 10:04 PM
AL NZ
Sep 4, 2015 08:39 PM
XFR_Gold
Sep 2, 2015 12:24 PM
