Supercharger cooling improvements?
Old Jun 26, 2022 | 08:39 PM
Remnant1's Avatar
Default Supercharger cooling improvements?
I'm looking at trying to upgrade the cooling system in the SV8 in anyway that I can, does anyone have any recommendations?
The most common upgrade grade I've seen is the Bosch 010 charge pump, if anyone has done that, how was the installation process?
Old Jun 27, 2022 | 05:41 AM
fivel's Avatar
Yes, I've done that, its quite easy. Just take the front bumper off and its right there and the RH side. The main issue is making sure you get it wired the right way around. The rubber housing that holds it on needed a bit of adjusting for the size of the new pump.
You can prevent loosing all the coolant by clamping the hoses.
There's a thread on it here:
https://www.jaguarforums.com/forum/x...pgrade-152574/
In that thread they had to make up the connector from the pump to the wiring harness, but mine came with the pump connector wire with some free tails so I just chopped off the harness connector from the old pump and replaced the wires in the pins.
Old Jul 30, 2022 | 05:37 PM
Remnant1's Avatar
It sounds like it's a fairly easy and straight forward thing to swap out.
Want to make sure this is the right one before I purchase it
Old Aug 1, 2022 | 10:36 AM
Aarcuda's Avatar
Youre in australia so I hope that price is equivalent to $130 us. Or else youre getting ripped off. But the number looks correct
NotGotAJag
Jul 9, 2020 11:24 AM
jordanmc
Nov 8, 2016 05:22 PM
covshark
May 19, 2013 12:01 PM
mark campbell
Jun 26, 2012 11:17 AM
warrjon
May 17, 2011 06:48 AM
