Supercharger coupler / isolator diy?
Old Jul 6, 2019 | 08:58 AM
Adam J's Avatar
also, seems that some feel the snout can "maybe" come off with the right wrenches or ... - no way no how. the S/C needs to be off and completely unbolted to remove the snout. i cut up wrenches to try and short cut - didn't help
so the parts are $30 or $300 or ... - all depends on what and how much you choose to do
it's the labor that gets you - probably $140/hr shop rate. if 8 hrs book rate then well over $1,200 with sales tax applied
i think it's wise for folks to plan on 2-3k budget once you need to do the inevitable "basics".
call it Jaguar tax or call it what you will, but if you're driving an originally 70k to 90k car, you'll have maintenance cost accordingly
the do it yourselfer has all the same costs - even with their "free" labor, as they've probably equipped themselves with all the tools and shop space to do the work
Old Oct 8, 2019 | 08:38 AM
clubairth1's Avatar
Community Influencer
What was the thread size on the rods you used to pull the Super Charger free from the engine?
I have read they are 8mm?
Old Jan 18, 2020 | 01:26 PM
Itsthatboi's Avatar
I work at a Indy shop and I’ve done at least 6 of these supercharger removals/rebuilds it does has to come out. No need to make the tool to get it off the dowels pry bar on each side wiggles it off. Also as far as splitting the snout off the unit a large cold chisel or wedge works perfectly to release sealant.usually have it off in about 2 hours. Any one attempting a diy feel free to message for tools and pointers.
Old Dec 28, 2020 | 07:45 PM
Mr jag's Avatar
Hello I read your info on the isolator replacement. Since I have the supercharger of I noticed you guys mention oil. When I took my supercharger of it had some oil in on the little reservoir/crevice next to the electric flap, I'll see if I could post some pics identifying the oil, anyway should that oil be there? And also you mention to replace the oil is there another location where the charger has oil?
The yellow highlighted area is where I found some oil when I took off the charger, does anyone know if this is normal? When I stopped by a local shop they mention that there shouldn't be any oil in there
Old Dec 28, 2020 | 10:10 PM
TXFireblade's Avatar
It's from the PVC system. unless there was a significant amount I wouldn't worry about it.
Old Dec 28, 2020 | 11:37 PM
Oxidizer2k's Avatar
there’s a little screw on the back of the supercharger that you have to take out to do the supercharger oil.
Old Dec 29, 2020 | 09:44 AM
clubairth1's Avatar
Here is a nice thread from the F-Type guys with pictures.
SC Oil Change
Old Sep 25, 2021 | 04:29 PM
  #28
Sam G's Avatar
Default Jaguar XF 2013 supercharger. Good day anyone knows if the supercharger takes oil
[QUOTE=JBzXJ40;1649328]It says in Topix to remove the supercharger. Once you start taking it apart you might be able to get access to all the bolts for the snout. If not, then most likely you will have to take it out, but I'm pretty sure I've seen a Land Rover tech do this job without removing the supercharger.
REMOVAL AND INSTALLATION
Loading...
Removal
CAUTION:
Make sure that all open ports are covered to prevent any foreign material ingress.
NOTE:
Some variation in the illustrations may occur, but the essential information is always correct.
  • WARNING:
    Make sure to support the vehicle with axle stands.
    Raise and support the vehicle.
  • Refer to: Supercharger (303-12C Intake Air Distribution and Filtering - V8 5.0L Petrol/V8 S/C 5.0L Petrol, Removal and Installation).
  • CAUTION:
  • CAUTION:
Installation
  • CAUTION:
  • CAUTION:
    Apply a continuous bead of gasket sealant as shown on the illustration. The application of the sealant must be 1mm diameter. Install the component immediately after applying the sealant without smearing the sealant.
  • Torque: 27 Nm
  • Torque: 5 Nm
  • CAUTIONS:
    • Make sure that spring resistance is felt in both directions of the pulley as shown.
    • Make sure that all open ports are covered to prevent any foreign material ingress.
    NOTE:
    Supercharger rotors will appear polished, this is normal
I open my supercharger and there was no oil in the back does it take oil in it ?
Old Nov 1, 2021 | 10:43 AM
JamT's Avatar
I am in the process of changing the coupler in my s/c and have reached the stage of removing the snout and now trying to get the old coupler out. Assuming the new one goes back in easily I too wonder about oil. I know it needs oil but since I have the s/c open can I get the old oil out and new oil in without having to get at the drain plug at the back?
Suggestions appreciated
James
Old Nov 1, 2021 | 11:00 AM
  #30
clubairth1's Avatar
That's what the drain plug in the back is for. Remove the screw and drain the old fluid then replace with new fluid.
No other way to do it.
Old Sep 19, 2022 | 05:29 PM
  #31
SanFran's Avatar
That's a great wayo to remove the Supercharger.
What's the thread size and pitch for the rods going into the SC?
Did you get the rods from Home Depot?
Originally Posted by davetibbs
I speak from experience that anything rear of the supercharger, even with all the scuttle panels removed, is a complete pain in the *** to get to. There's a wiring connector for the sound symposer, one for the IAT sensor on the other side, and these wiring looms have almost no slack in them. Furthermore, I found the plastic casing around the engine wiring loom at the back to be pretty much impossible to open and remove the wiring loom from.
The workshop manual is as useless as always with this, going no further than "Simply remove X"
And that's before you even get to remove the supercharger, which for me was a job in itself. There are two locating dowels underneath the supercharger which are interference fit, requiring me to buy and drill some metal bar section, thread some rod (M8 if memory serves) through it, and a strong friend to help me rock it off the engine. We tried without the bars and it was just impossible to get the supercharger to move at all.
I also found removal of the snout was ..... interesting. The technique that I found to work in the end was to back out all the snout bolts 1/2", hold the supercharger by the snout and then and then smack the sh*t out of the joint with a rubber mallet. The weight of the supercharger should break the seal, and the bolts stop it crashing to the ground. Might be worth putting something soft underneath it in case you drop it anyway. Based on how much it took to break this seal I really question how easy replacement would be with the supercharger still on the engine, but I'm sure it's possible.
Consider replacing the isolator with a solid one, they're available on eBay. Important: if you do go with a solid one, don't make the mistake I made - make sure the solid coupler slides freely onto the hubs before putting the supercharger back together/ - I needed to spend a good 30 minutes going at the holes on the coupler with a small round file to achieve this.
Old Sep 20, 2022 | 09:52 AM
  #32
clubairth1's Avatar
Jaguar did put a place to pry when removing the SC snout but it's a bit hidden?
After removing the SC and snout turn it over to see where to pry.
Old Sep 13, 2023 | 08:23 PM
  #33
whosyobobby's Avatar
Can anyone show me where you would place the wedge to seperate the snout? I've got a 2016 XF 3.0l SC. That sealant is really sealed pretty good and I can't get it to break free.
Old Sep 14, 2023 | 12:32 PM
  #34
clubairth1's Avatar
Yes. Jaguar made a spot to pry it off on the bottom of the snout.
In the Jaguar documents they recommend this sealant;
Loctite 515 about $15-$20 others have used different products.
Loctite 515
Old Sep 14, 2023 | 12:39 PM
  #35
Loctite 515
Thanks! I'll have a look tonight. I'm still leary that too much force on the cast aluminum will just snap a tab like that right off.
Feb 1, 2026 02:24 PM
dsnyder586
Feb 2, 2023 06:47 PM
aholbro1
Oct 2, 2015 10:39 PM
Brake buster
Feb 1, 2015 03:26 PM
