Supercharger Rattle?
Jasin Dhaliwal (02-06-2017)
Received 3,131 Likes
Also, that's the TSB for the 5.0 V8, see here for the TSB for the 3.0 V6: https://www.jaguarforums.com/forum/x...4/#post1608731
Same problem but different parts.
Also, I'm taking my F-Type in tomorrow to get the quite loud engine noise fixed, and I was told when the tech diagnosed it a couple of weeks ago that it wasn't the SC torsion isolator rattle, instead it was the drive belt tensioner bracket rattling, or so he thinks. Exactly which drive belt (SC or other) and which tensioner/bracket I wasn't told, I'll find out Thursday afternoon one way or the other and report back!
Thanks once again!
You will hear a slight clunk when shutting down, but it shouldn't be that obvious.
Hard to explain... mine sounds like clu-clunk. ..... almost like the engine did another rotation and very noticeable. I listened to one with it replaced... more of a muffled , but there.
You will hear a slight clunk when shitting down, but it shouldn't be that obvious.
Jaguar dealer essentially said its fine, and this sound is 100% normal. Told them to compare it to another XF 3.0 SC standing there and that made no noise, and then they tried blaming that on the fact that XF was running cold, and would make a noise while shutting down after it warms up . After about half hour of arguing they ended up sending a sound clip to Jaguar (god knows why they couldn't just get it in and dig deeper themselves) and told me to sit tight to 48 hours till they get back to me.
Not the easiest bunch to deal with to say the least,.
Collected my F-Type from the dealer a few hours ago, and as I suspected the engine rattle has not been fixed.
They replaced the idler tensioner/bracket (on the main drive belt not the SC belt) they thought was the cause and no change, it still rattles.
So it's booked in again a week from today to this time replace the SC torsion isolator, which was my original diagnosis.
Mucho stuffing about, inconvenience and petrol cost, with no guaranteed fix yet.
The dealer in my city is being very uncooperative. Haven't called me back here with what the head office of Jaguar said in regards to the sound clip they sent them. Planning on calling corporate at this point and see what that say. Send this video to another dealer 3 hours away from my city, and they said there's something wrong with it for sure. May end up having to drop it there now. Absolutely unacceptable from Jaguar.
I had a bit better luck with my dealer, they accepted without any argument that the engine was rattle was too loud to be normal and needed to be fixed. Lucky they did, as the next closest dealer is 8 hours away!
The following 2 users liked this post by OzXFR:
George05 (05-21-2020),
Jasin Dhaliwal (02-09-2017)
Received 2,184 Likes
I cant see you tube at work but can tell you that if youre reffering to a clunk at shiut down it is the tolerance that is needed between the rotors. You notice this is the spring isolator while idling osilates between 5-20* before and after at rest centering. So when you shut down it goes to center and you hear the rotor knock. Did i explain that well enough?
If you get a chance to see the Youtube, the vacuum line loop on the right had bank, is above the plastic engine cover, and is wearing a groove on the supercharger badge, So I have tucked mine underneath the plastic cover, bit too late now. Is this were it is meant to go, I have seen them above and below the engine cover.
Jasin, have you had the water pump changed yet?
Yes, appears to be a little louder than mine.
Yes, it is still under warranty!!
I would go back and speak to the dealer first before Jaguar HQ.
The dealers do tend to be disgustingly polite....
I mean crawling and scraping polite without any technical knowledge or abilities.
Reminds me of a scene in Pretty Women. You Know the one.
The dealers sell cars. Jaguar manufacture and honour the warranty on that car.
You are correct, generally dealers give no feed back on issues, just e mails and phone calls to fill in their feed back forms. On how do you find our service?
Well fill it in.
I would go back to the dealer and explain your concern, with the loud engine noise and you do require feed back so this is recorded in the service history, before you may have go to Jaguar HQ if this is not resolved to your satisfaction.
There is no point, at this stage making a big deal about it on a public forum.
(If you know where I am coming from.)
