Tire pressure monitors
Old Jun 13, 2016 | 07:26 AM
  #41
Long Islander's Avatar
I would check with a tire shop and see if they can supply Jaguar OEM sensors and install them. They should also be able to diagnose the issue first because they probably see a lot of this issue.
Old Jun 14, 2016 | 06:24 AM
  #42
Dallas Rockford's Avatar
Default How can I disable the TPMS?
I'm new to owning a Jaguar and mine is a bit older. With that being said, I am very old to the usage of the TPMS's and believe, like some, that they are more trouble than they are worth.
I've owned 3 other vehicles with this technology and it was a struggle, as I've similarly noticed with the Jaguars.
Current message states the TPMS is not reading the front passenger tire - and of course, the tire is fine.
Does anyone know the procedure to disable this system? (Secondarily, is there a reset procedure?)
Any info is much appreciated. Flashing light starting to make me crazy!
Old Jun 14, 2016 | 06:33 AM
  #43
DPK's Avatar
DPK
Big D..As has been mentioned, the most likely problem with a car of your age is that the sensors (x-mitters) in the tires have weak batteries and needs the whole sensor replaced...Read backwards on this thread, as some experience issues with after market brands and some have no issues with OEM sensors..They are pricey little devils, not including the installation cost too.
Old Jun 14, 2016 | 08:38 AM
  #44
According to the records, they were replaced not quite 2 years ago. I feel these things are pretty flaky and just want them gone.
Thank you for replying!
Old Jun 14, 2016 | 08:49 AM
  #45
08292's Avatar
Here on forum there is one man in New York area who could totally disarmed TPMS system in your car and enable or disable some option.
Old Jun 14, 2016 | 05:35 PM
  #46
Default Who knows how to disable the TPMS?
I'm intrigued - who is this person? Thank you!
Old Jun 14, 2016 | 06:47 PM
  #47
OzXFR's Avatar
DR, check out post #19 in this thread.
It takes some expensive equipment and good knowledge to disable the TPMS, but it can be done.
Old Jun 15, 2016 | 03:11 AM
  #48
08292's Avatar
Send you PM
Old Jul 17, 2016 | 04:07 PM
  #49
n8ertot's Avatar
FYI, in case others come here later - I FINALLY fixed my issues after replacing the TPMS module twice and all the tire sensors twice as well as having them programmed by a tire shop and Jag multiple times.
I DID NOT have to get rid of my aftermarket wheels, so don't let Jag tell you that's the problem. A wheel is a wheel and all a sensor cares about is whether or not the air it's in has the right pressure.
The final fix was to buy some (used) Jag official sensors. Now, like many things, there are only a few different companies that actually manufacture TPMS sensors, so I'm willing to bet that there's some programming whereby Jag is looking for official sensors. It's scammy, but that's what you have to do.
Old Jul 18, 2016 | 05:38 PM
  #50
BritCars's Avatar
Just to be clear I don't think Jag is telling people there is an issue with aftermarket wheels. They are fine. The issue is that if you don't use OEM sensors then there are compatability issues. Sometimes they work, sometimes they don't. Seems like if you change to OEM sensors like you have, that is a pretty common fix. I'd be surprised if this was deliberate - just seems that the Jag system is sensitive and the OEM sensors work best
Old Jul 18, 2016 | 10:41 PM
  #51
lotusespritse's Avatar
Did you go with used sensors just because of cost, or some other reason?
I wouldn't want to put used sensors in there unless I was selling the car because who knows if they will die in a couple of months and I am going through that all over again...
Old Jul 19, 2016 | 05:39 AM
  #52
MarkN's Avatar
My sensors are on now too - playing tire roulette. I changed the TPMS sensor a couple years ago but appears shot again.
I love this car but it feels like every couple weeks or so a new warning light....
Old Jul 22, 2016 | 05:59 PM
  #53
The dealer checked my car out and reset things, so no warning lights for 3 weeks now.
I am ready for whatever happens, boy those warning lights are really a drag.
Old Jul 23, 2016 | 05:29 AM
  #54
MarkN's Avatar
Driving last night I got new warning lights I've never seen before.
1. Tire pressure monitoring failed (yellow)
2. Tires pressures are not being monitored (red)
For something as dumb as tire pressure they have 10 different lights and you don't need any of them because you can see or tell when you need,air!
But the warning system is worse than what it's designed to monitor.
Old Jul 29, 2016 | 03:49 PM
  #55
Sterling Smith's Avatar
My car was giving me a tire pressure light intermittently going on and off randomly. Half the time the pressure was correct, the other half, there actually was a low tire. The last time it went off, I was like not again, I just checked it earlier today! So I go to the tire shop to see if there is a leak and found no leak in the tire at all. They submerged the whole tire in water and nothing came bubbling up. Then they pulled the tire off and found this:
Factory rim
I had no idea. Never would have guessed. The rims on our cars must not be very robust, and the factory contis are not that good because I have not hit anything out of the ordinary. I hit a pothole about 1 1/2" deep at 30mph once in the rain because I couldn't see it (didn't feel it either). This is on the inside of the wheel. Never would have seen the crack had it not been pulled off. I am never using continentals again. Going Michelin and changing the batteries in the TPMS sensors the next set. Already had to replace one of the continentals. I have never had this much trouble with tires before, because I always buy Michelin. I'll replace the wheels with something forged after this... already getting quotes.
Old Jul 29, 2016 | 10:45 PM
  #56
BritCars's Avatar
Factory rim
I had a similar issue with one of my OEM Selena wheels. They are a bit fragile / soft. Nothing to do with the tyres though - just not a very strong rim. I'm amazed they didn't find that in a leak test...
I don't think batteries are replaceable on the tpms - you will need new sensors.
dabank
Nov 28, 2015 08:02 PM
atxtonyc
Nov 28, 2015 01:34 PM
Steveh
Nov 28, 2015 11:52 AM
tommyd
Nov 27, 2015 08:44 PM
RickyJay52
Nov 26, 2015 08:47 AM
