transmission fault
jaguar xf supercharged 2009 when the gear change between the 3rd and 4th gear its sleeps and the fault comes on . if im on D gear . if im on S gear its a bit better if im on S gear with race mode on its almost ok .i can go down from 4th gear to 3rd gear no problem at all, but from 3 to 4 it sleeps
my car have 65000 miles on it or 105000km , we try to reset the transmission at the jaguar end up it was worst then before couldnt drive anymore they tried to fix it 3 to 4 times and i left the dealer with a 600$ bill with a car worst then before . they told me i need a new tranny 15000$ (seriously ...)
the only thing i found weird is that i had the exact same problem with a bmw 335 2007 and a guy really fixed my problem by flushing the oil , replace a little gasket that looks like a donut and the remap the tranny and it was just perfect
No idea what it costs. But it would be much cheaper to have it done at a tranny shop. Jag dealers will charge you an arm and a leg and maybe even more. I did mine myself and the parts only cost a couple hundred dollars.
Did you find a way to fix the problem?
[QUOTE=croco;1794170]Sounds like you are low on transmission fluid. Check your fluid level. If not try to reset the transmission. If all that doesn't work then you might have worn clutches
How do you reset the transmission fault light?
