Transmission issue
Old Apr 25, 2016 | 11:30 AM
  #41
nasa25's Avatar
Has anyone ever just did a flush and refill without changing the pan/sleeve. My mechanic threw this idea at me but I'm not sure how I feel about not changing out the filter (built into the pan). I'm assuming most of the value of the transmission service comes from actually swapping out the fluid but not sure if keeping the old filter in would be a bad long term idea.
Old Apr 25, 2016 | 12:12 PM
  #42
DPK's Avatar
DPK
First..how many miles on the original filter/fluid?..If more than 60K, it is suggested to change the pan/filter too..If it is less, say around 40K, then just do just a flush refill..My dealer suggests the same approach...the magnets in the bottom of the pan hold the metal junk so that won't break free...But, it's the high mileage sludge that might break free during a flush and plug the filter more....All iffy to me
If you can afford it and for peace of mind..I'd do the whole pan/filter deal..Why cut a corner for sake of a few extra bucks, is all I'm saying.
Old Apr 25, 2016 | 12:24 PM
  #43
nasa25's Avatar
131k km. So around 80k miles. I feel the same way. Plus I want my mechanic to inspect the pan and make sure there isn't a ton of metal shavings floating around in there before he blows the old fluid out of the torque converter.
Thanks for the input.
Old Apr 25, 2016 | 03:57 PM
  #44
Bigg Will's Avatar
Honestly if you do have sludge in your trans, your trans is already on its way out. The same holds true with excessive metal. I never do flushes only fluid exchanges (NO CHEMICALS OTHER THAN NEW TRANS FLUID IS USED), then I change the pan filter and refill. Magnets will pick up the steel and iron, but not the brass, aluminum or clutch material that is also present in your used trans fluid .Please note the quote highlighted in red below. Trans fluid is mostly detergents and anti foaming agents, so it accomplices great cleaning on its own, it's the dirt suspended in that trans fluid you want out.
Old Apr 26, 2016 | 03:12 PM
  #45
Spider85's Avatar
nasa25 do not save money on important things on your Jag
Old Apr 29, 2016 | 07:03 AM
  #46
nasa25's Avatar
I agree. I'll be having my shop do a full flush and refill including replacing the pan/filter and sleeve.
Old May 11, 2016 | 01:29 PM
  #47
Spider85's Avatar
Not good guys, gave back my car for a repair, they changed oil and pan, they drove a several miles and rang me that the car now jerks and has a problem with changing gears starting from 1-2, the took it back on Monday to the garage, tomorrow should be an answer. I am without a car since 23th April
If they refuse to repair I will go to small court, I am loosing my patience
Old May 13, 2016 | 04:30 AM
  #48
Bigg Will's Avatar
A gear range selector on its way out can cause similar issues.
Old May 13, 2016 | 11:33 AM
  #49
Spider85's Avatar
But why after oil change it got worse?
Spoke to them today, they said there is no faults on the gearbox, but problem exists, Monday they will strip down gearbox, fantastic
Old May 13, 2016 | 12:31 PM
  #50
jagwower's Avatar
Did they use a vacuum and/or pressure system to flush your trans? Or just let it gravity drain?
Old May 13, 2016 | 02:24 PM
  #51
Spider85's Avatar
I don't know to be honest
Old May 13, 2016 | 02:52 PM
  #52
Bigg Will's Avatar
True, just one of the problems I'd look at based on your issues.
Old May 13, 2016 | 04:50 PM
  #53
Madart's Avatar
If you're suggesting that they didn't do the drain properly and then overfilled the tranny I'd be suspicious of this too especially seeing it's developed a hard shift AFTER the work they've done where it was slipping beforehand.
I'm not sure I'd want these guys stripping my transmission.
Old May 14, 2016 | 06:03 AM
  #54
Spider85's Avatar
It is an independent Jaguar garage, they should know what they are doing (hopefully), at least I do not pay for this repair
Old May 16, 2016 | 10:59 AM
  #55
Bigg Will's Avatar
I did a drain and fill without changing the sleeve.
nasa25
Jun 18, 2025 03:07 PM
newbee
Mar 8, 2016 01:14 PM
matade
Mar 7, 2016 07:11 PM
timfountain
Mar 3, 2016 08:32 PM
Mihai Gherghina
Mar 3, 2016 02:15 PM
