Trunk not opening
Old Sep 16, 2013 | 05:54 PM
axr6's Avatar
Default Trunk not opening
I had our 2012 XF at the dealer about a month back with the trunk not opening electrically, only by the use of the physical key hidden in the FOB. They replaced a switch which appeared to temporary fix the issue. Today, my wife once again could not open the trunk electrically or with the key. I've read here that someone had a similar problem that took a long time to fix.
Wondering what problem was found?
Albert
Old Sep 16, 2013 | 06:46 PM
jagular's Avatar
Rumour is there is a break in the wiring harness where it passes into the trunk which can cause this fault. It begins as n intermittent fault and then gets permanent.
BadKat174
May 26, 2023 12:29 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
DuhCar
Sep 11, 2015 10:58 AM
findre
Sep 10, 2015 05:46 PM
speacock
Sep 10, 2015 12:14 AM
