TSB for '09 XF for creeky roof liner
Old Oct 12, 2011 | 02:22 AM
XF-C's Avatar
Default TSB for '09 XF for creeky roof liner
I had some creeky noise on my roof liner and the service department pulled up a TSB about this problem and had replaced some clips and seal. Sorry, I chucked my invoice so I coud not include the number.
Old Oct 12, 2011 | 10:36 PM
Need4Spd's Avatar
Do you know if the TSB is only for '09s or applies to later models (specifically an '11) as well? I notice a bit of creaking when entering driveways (I guess the chassis does twist a bit), and it seems to come from the headliner.
Old Oct 17, 2011 | 04:10 AM
XF-C's Avatar
I am not sure if the TSB is for all years. The tech came for a test drive and pushed his hands against the roof liner and the rattle noise was gone so he confirmed that this falls within the TSB details. They knew about that Jag upgraded the clips.
The creaking that I still have as well wouldn't be covered under warranty party it was beyond 1 year and the creaking is mainly from twisting/torquing of the chasis.
Old Oct 21, 2011 | 10:53 AM
XF-C's Avatar
TSB 00209 rattle noise from roof opening panel
And
TSB JTB00144 - creeking noise from roof liner.
Replaced clips for roof liner and sunroof guide seal.
Old Oct 21, 2011 | 11:14 AM
XF-C's Avatar
Please post your feedback if you are had experienced diff roof noises and how did the service department resolve it? I am still hearing qweeking noise but no obvious rattle or tick noises anymore. The XF body twisting is horriblely bad for this class of car.
Old Nov 4, 2011 | 03:14 AM
XF-C's Avatar
I just found out there is a TSB for squeeky door seals.
Old Nov 4, 2011 | 08:21 AM
pmarold21's Avatar
Default Please do post this TSB# if you can
Please do post the TSB # for the door squeak if you can. Thanks
Old Nov 4, 2011 | 09:29 PM
chekraze's Avatar
yes, when I back out or enter my driveway I am getting some sounds and wasn't sure where it's coming from. I'm not used to that.
Old Nov 4, 2011 | 09:30 PM
chekraze's Avatar
And that combined with the brake squeal are not impressive as I pull into driveway. Hopefully neighbors won't notice and spare me the embarrasment
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
tlynch
Dec 31, 2020 01:58 PM
philwarner
28
Jul 11, 2017 10:21 AM
King Charles
Oct 16, 2015 01:25 AM
