Tying down the trunk
Old May 10, 2016 | 04:59 PM
TerryinNC's Avatar
Default Tying down the trunk
Got to haul some lawn timbers and need to tie the trunk lid down. Anybody have a trick for doing this? Its so nicely closed and covered up in there there's no place to hook a bungee. I'd take the liner off temporarily but how to undo the fasteners. They have a phillips head but turning them doesn't do anything. ??
2014 XF
Old May 10, 2016 | 06:46 PM
OzXFR's Avatar
Those fasteners are called scrivets, the most damnable invention ever. The centre "screw" is supposed to screw out but most of the time it just turns and goes nowhere fast, as you have discovered.
Several things you can try to get them out.
First, grab a trim removal tool (or if you haven't got one a thin flat blade screwdriver) and lever under the outer edge of the scrivet, so there is some tension on the "screw", then see if it will turn out.
If that doesn't work (and it usually doesn't), get hold of a jeweller's flat blade screwdriver, the smaller the better, try to insert it between the head of the screw and the outer part, and try to lever the screw up a bit. If you succeed in getting the screw up about 1 mm then grab a bigger screwdriver, insert it in the gap, and lever the screw out some more. With any luck you will get it out far enough to grab it with your fingernails or some small pliers and yank it right out. Be warned, inserting the screwdrivers and levering often damages the head of the screw a bit. The scrivet will still work but it might look a little ugly, so it pays to have some spares on hand.
Old May 10, 2016 | 06:57 PM
2010 Kyanite XFR's Avatar
Scrivet - those damn trim things where upon disassembly, the center piece always flies somewhere it's not supposed to (and which is also usually inaccessible). Compounding that fact is they are plastic and the magnet on a stick can't help retrieve it like with a screw.
Although they confound me a lot less than they used to when they first appeared.
Old May 10, 2016 | 07:51 PM
TerryinNC's Avatar
ozXFR
Many thanks. Just got back home. Will try first thing tomorrow.
Cherry_560sel's Avatar
Sorry...why don't you rent a truck from Homedepot or uhaul? why would you want to haul wood in you Jag? The truck rental is like $20...and why are you two encouraging him!!!
Old May 10, 2016 | 07:58 PM
TerryinNC's Avatar
The Jag is my car. My daily driver. When I need to go places or haul stuff its in the Jag.
Old May 10, 2016 | 08:00 PM
just curious....what other things can you stuff in your jaguar? I can barely fit a car seat back there...and there is barely enough room for my leggy blond...
;0
Old May 10, 2016 | 08:02 PM
Large bags of kitty litter for the occasional internal fluid leakage?
Old May 10, 2016 | 08:04 PM
DPK's Avatar
DPK
Silly,use the restroom before you leave home..
Old May 10, 2016 | 08:07 PM
DPK, for the Jag, not me!
Old May 10, 2016 | 08:09 PM
TerryinNC's Avatar
Haven't had anything sticking out the moonroof yet, but the time may come.
Old May 10, 2016 | 08:21 PM
Please don't have your wood sticking out of the sunroof. It's terrible for aerodynamics and people might take embarrassing photos or 5-0 might think it indecent
Old May 10, 2016 | 08:34 PM
OzXFR's Avatar
Originally Posted by TerryinNC
ozXFR
Terry,
I just had a little play around with the scrivets holding my boot liner in place, and all except two unscrewed no problem. For the two that didn't I inserted my trusty dirt cheap "car door panel remover" tool under the base of the scrivet, and both times the screw now turned out. Go here to get one: Car Door Panel Remover Body Retainer Clip Auto Trim Upholstery Pry Tool | eBay
Old May 10, 2016 | 10:07 PM
TerryinNC's Avatar
Bought one for next time. Thanks again.
Old May 11, 2016 | 01:43 AM
Rivguy's Avatar
I would hesitate to carry anything sticking out of my sunroof. If the weight should rest against the open panel it might damage the probably plastic gears or track, Not a good idea or way to save money. Maybe consider adding a hitch for a small trailer?
Old May 11, 2016 | 07:05 AM
DPK's Avatar
DPK
I think it was mainly a concern for 2010 Kyanite XFR, as he seemed to have a 'wood sticking out' fetish...
Old May 11, 2016 | 11:51 AM
TerryinNC's Avatar
After quite a few minutes mucking about and damaging (as you predicted) scrivets, I just jammed the bungee cord up into the latch and snapped it closed. Worked fine.
Old May 12, 2016 | 12:20 AM
Ouch!....hahaha
xkeots
Jul 26, 2020 12:35 PM
eshea
Nov 16, 2019 09:49 AM
scardini1
May 17, 2016 11:01 PM
juha_teuvonnen
May 12, 2016 09:07 AM
Grrrmachine
May 10, 2016 07:06 AM
