upper control arms.
Old Feb 26, 2017 | 07:05 PM
frogbodman's Avatar
Default upper control arms.
so I looked around here first to see if I could find an answer, couldn't. I need to change my upper control arms because my ball joints at F*****. thanks Hawaii roads. I cant seem to get the bolts that hold the bushing in, out. the just hit my springs/shocks. do I have to remove all of the suspension to get these simple things out?!
Old Feb 26, 2017 | 11:01 PM
Bigg Will's Avatar
Year and model would help
But generally the shock and spring assembly need to come out to remove the upper control arm bolts.
Old Feb 26, 2017 | 11:07 PM
frogbodman's Avatar
haha my bad 2009 xf.
so jag designed it so something completely unrelated is in the way just so I have to take a butt load more things off to change 2 bolts. figures
Old Feb 26, 2017 | 11:14 PM
OzXFR's Avatar
And to make it worse, you need to unbolt and push out of the way a couple of the suspension links before you can wiggle the front strut assemblies out.
Not really a DIY job, soooo much easier on a hoist (unless of course you are lucky enough to have your own hoist).
Old Feb 26, 2017 | 11:31 PM
frogbodman's Avatar
I guess I'll make the shop do it when I get my safety inspection. Thanks for the info man
Old Feb 28, 2017 | 02:06 AM
Bigg Will's Avatar
Glass 1/2 full, it be a good time to give all the suspension components a good look at.
Old Mar 1, 2017 | 05:01 AM
Shadow993's Avatar
I believe I disconnected the shock mount from the top to allow it to move enough to remove the two bolts. As for the bolt joint, I just let the suspension pull and used a pickle fork.
The hardest part on the passenger side was getting to the nut that's inside the engine Bay under the fuse box on the firewall side. I used a telescoping magnet to stop it from falling on removal and install.
If you research s-type jaguar it's the same set-up.
Old Mar 3, 2017 | 03:23 PM
damienedwards's Avatar
I spent a solid day changing my upper arms..........was actually swappingvthe upper arm bushes for poly versions which I highly recomend, really tightens up the front end feel and noticed no difference in nvh.
was a nightmare job though as si many parts have to be removed........plenum, fusebox, water resevoir, shoks top and bottom bolts.......good luck
