USB interface
Old Nov 11, 2012 | 03:27 PM
Kashifns's Avatar
Default USB interface
Hi,
I just bought jaguar xf diesel luxury 2010. It have AUX connecter in it but no USB and iPhone connection. Can we actually get it modified to have USB and iPhone connection?? Please advice. Thanks.
Old Nov 11, 2012 | 05:53 PM
miamijag's Avatar
Yes you can but will be to expensive to do it at the dealer. You probably better just use aux port
Old Nov 12, 2012 | 03:49 AM
Kashifns's Avatar
From where i can buy aux port? Any link please.
Old Nov 12, 2012 | 06:20 AM
Chrzesm's Avatar
I had the same setup, ie w/o USB/IPod module. I managed to buy second hand
PAM (Portable Audio Module) and USB/Ipod console with (this is important) original cable and fiber optic (I paid for all ca $200). The module needs to be connected in MOST (Media Oriented System Transport) optical link between Bluetooth and Integrated Audio Module (below driver's seat). Now, having the module in the optical loop, you need to reprogram CCF (Car Configuration File) adding the module to XF system configuration (you need to tick one register on the CCF file), after CCF repro you need clear all trouble codes (there will be many when you open the optic look adding PAM in MOST). I recommend the CCF reporgramming should be done by experienced person using a good, stable tool (some Chinese programming tools can simply lock your car and ruin your pocket). After reprograming, you should see a new menu with USB and Ipod functions :-). I did it last year and it works perfect.
Old Nov 12, 2012 | 01:51 PM
Kashifns's Avatar
I looked all over internet for PAM, couldnt find one. Can you help on that? I will take it to some professional for fitting. Or anyone in forum can offer supply and fit service. I will take that. I am in london, UK.
Old Nov 12, 2012 | 02:03 PM
Kashifns's Avatar
Will something like this will work??!
USB A Female to 3.5mm aux 1/8 Male audio F/M adapter jack Converter Charge Cable
http://bit.ly/TvMcsw
Old Nov 12, 2012 | 02:17 PM
miamijag's Avatar
No it is not going to work
Old Nov 12, 2012 | 09:10 PM
Kashifns's Avatar
I am buying
http://justjagsuk.com/product_detail...7/?model=XF&q=
And
http://justjagsuk.com/product_detail...e/6424/343874/
Anything else??
Old Nov 13, 2012 | 05:41 AM
Chrzesm's Avatar
Kashifns, above a picture of my PAM with fibers and a black cable to the console (C2Z3491) your are buying.
I do not recall the Audio Connectivity Module you mentioned. Probably it is the one already inserted in your C2Z3491 - please double check before buying.
Old Jan 31, 2013 | 07:44 AM
RegGraham's Avatar
I have added the PAM and PIA and Most fibres etc as per post form Chrzesm. When I asked my local dealer to reprogram the CCF he didn't know how, when he aske Jaguar they said it couln't be done!. I have access to SDD and a VCM I think its v132 SDD does someone have the instructions on how to modify the CCF for the PAM/PIA as I won't have it long enough to mess about and learn how it works.
If not i will have to find an indepent repair shop near London who can but they do not advertize.
Old Feb 1, 2013 | 09:46 AM
Chrzesm's Avatar
RegGraham, Give me your personal email please. Somehow I cannot send you a private message (no access). Thx
Old Feb 3, 2013 | 01:08 PM
RegGraham's Avatar
I can't access private messages so email me on reg.graham@me.com
Old Feb 12, 2014 | 06:53 AM
alistair2112's Avatar
Hi i got the usb interface.I got it all fitted showing jaguar logo on the i pod took it to my local autologic guy.He cant find the module in the car with autologic he called support they say it cant be done.Any help would be great
Alistair
Old Feb 12, 2014 | 10:18 AM
JagV8's Avatar
Maybe avoid autologic and try a Jag tool like IDS/SDD?
Jul 9, 2018 01:44 AM
TXJagR
Jun 20, 2016 01:02 PM
flyrr100
Sep 18, 2015 06:31 PM
jagent
Sep 12, 2015 01:40 AM
