valve timing 5.0 s/c 2010 range rover
Having rebuilt this 2010 5.0 s/c from the ground up new chains, guides, valves etc and now running is there an intake timing issue that's causing my problem?
I get p0308, p0316, sometimes p0306. I have swapped coils, injectors , plugs and issue stays with cyl 8. Cyl 6 is ok most of the time. Obd misfire counter is #8. I have smoke tested intake and swapped maf sensors all ok.
Gap tool reading at hot idle
94.5 deg bank 1 intake. Exhaust 118 deg.
88.8 bank 2 intake, Exhaust 119deg
Not getting any timing correlation codes, however fuel trims are negative stft is - 7.81% bank 1 and -9.38% bank 2.
Am I in trouble with bank 2 intake compared to bank1 is it a tooth out on the intake sprocket bank 2 ?
TIA.
Jerry
TIA.
Jerry
Pmorphis
Jul 4, 2019 09:09 AM
