valve timing 5.0 s/c 2010 range rover
Old Jan 15, 2026 | 09:26 AM
jetfiremuck's Avatar
Default valve timing 5.0 s/c 2010 range rover
Having rebuilt this 2010 5.0 s/c from the ground up new chains, guides, valves etc and now running is there an intake timing issue that's causing my problem?
I get p0308, p0316, sometimes p0306. I have swapped coils, injectors , plugs and issue stays with cyl 8. Cyl 6 is ok most of the time. Obd misfire counter is #8. I have smoke tested intake and swapped maf sensors all ok.
Gap tool reading at hot idle
94.5 deg bank 1 intake. Exhaust 118 deg.
88.8 bank 2 intake, Exhaust 119deg
Not getting any timing correlation codes, however fuel trims are negative stft is - 7.81% bank 1 and -9.38% bank 2.
Am I in trouble with bank 2 intake compared to bank1 is it a tooth out on the intake sprocket bank 2 ?
TIA.
Jerry
Old Jan 15, 2026 | 01:35 PM
clubairth1's Avatar
Community Influencer
Just a guess here? Were the VVT's changed out? They have been reported to be fragile and can fail from handling.
Were the PCV diaphragms replaced when the SC was off?
Old Jan 15, 2026 | 01:56 PM
Yes PVC diaphragms replaced. smoke pipes all tested ok . Didn't change vvt
Old Jan 17, 2026 | 11:19 PM
dennis black's Avatar
20 Year Member
did you skip timing, if so i hope you didn't bend a valve
Old Jan 20, 2026 | 06:03 PM
kansanbrit's Avatar
Did you time the high pressure fuel pumps properly ?
jagoman
Jul 13, 2025 08:20 PM
hoppo5.0sc
Nov 12, 2024 09:54 AM
leftlanetruckin
Sep 10, 2020 09:37 PM
leftlanetruckin
Sep 2, 2019 09:13 PM
Pmorphis
Jul 4, 2019 09:09 AM
