weeping air bleeder?
Old Jun 15, 2021 | 07:31 AM
Brian H Smith's Avatar
Default weeping air bleeder?
Dear Listers,
Can anyone tell me what this is? I believe it is the "air bleed" location for the coolant system. It is "weeping" coolant. Now it hasn't lowered the level of coolant in the reservoir but I know its not supposed to weep. Any thoughts on how to get it to stop? It the round thing with the cross on it (But I'm guessing you all already figured it out.) This is the wife's daily driver and I really don't want it to let go on her.
Thanks,
Brian Smith
2013 XF supercharged 3.0L
Shreveport, LA
Thing in question
Old Jun 16, 2021 | 02:20 AM
chris.schneider's Avatar
Hi Brian
Yes, this is the air bleed location for the heater coolant pipes. These screws are prone to leaking, unfortunately Jag only sells the complete tube as far as I know. I'd guess that this https://rimmerbros.com/Item--i-LR055...BoCxU4QAvD_BwE would fit, but I never tried.
When I did the coolant pipes job I found mine un-cracked and simply exchanged the o-ring on it.
Chris
Old Jun 19, 2021 | 11:45 PM
davetibbs's Avatar
Yeah, could be something as simple as a new o-ring needed.
However, since these bleed screws are the same size/design as on BMWs, I highly recommend replacing it with this anodized one, as the plastic will eventually snap anyway. I have it and it's great.
Old Dec 15, 2021 | 02:51 PM
Can you tell me which BMW models have the same bleeder valve as my XF?
Old Dec 15, 2021 | 03:49 PM
davetibbs's Avatar
According to the fitment list on Autozone's site for a plastic replacement, most of them.
Old Nov 12, 2022 | 03:09 AM
Robb25's Avatar
Originally Posted by chris.schneider
Hi Brian
Chris
Hi Chris. Did you replace the metal pipe that has the bleed screw on it and if so how long did it take and any tips? Thanks, Rob
Old Nov 12, 2022 | 03:01 PM
Sorry, I did not exchange that pipe. Does not seem easy though.
Chris
jakesdad
Mar 1, 2018 07:55 PM
tramirez
Oct 29, 2016 11:51 AM
Americain
Oct 27, 2014 05:23 AM
Rique
Oct 23, 2012 09:30 PM
washuk
Apr 30, 2010 11:46 AM
