Wheel rotation, new rims and TPMS sensors...
Old Apr 10, 2019 | 08:24 AM
mrNewt's Avatar
Question Wheel rotation, new rims and TPMS sensors...
Is the XF smart enough to figure out when wheels are rotated on the car and "update" the new location of each sensor?
Also, planning to get some new wheels for this car in a month or so.
The new wheels will have new sensors on them - will the XF figure out that and update the new sensors, or is there a re-lean procedure that we can follow?
Old Apr 10, 2019 | 10:24 AM
Bigg Will's Avatar
Yes.
Old Apr 10, 2019 | 10:47 AM
mrNewt's Avatar
Simple, yet efficient - thanks!
Old Apr 11, 2019 | 05:28 AM
Bigg Will's Avatar
Y W. Just take a freeway drive after the tpms position change.
Old Apr 11, 2019 | 05:32 AM
Bigg Will's Avatar
Y W. Just take a freeway drive after the tpms position change. The new sensors need to be Jag sensor though, Ebay.
Old Apr 12, 2019 | 07:33 AM
mrNewt's Avatar
Jag as in... branded Jag or can be anything else as long as they are built for Jags?
I was going to order them from RockAuto.
Old Apr 12, 2019 | 05:40 PM
Bigg Will's Avatar
Jag as in Jaguar, aftermarket sensors will not work, believe me I know, https://www.jaguarforums.com/forum/x...k-xf-r-204805/
Make sure you get the frequency off of, and the same frequency as your original Jag sensors.
Old Apr 12, 2019 | 06:54 PM
BritCars's Avatar
I'll second that. The jag original oem ones are a lot more expensive. But a lot less hassle
Tried aftermarket ones once and they worked intermittently. Drove me crazy!
Old Apr 13, 2019 | 10:51 AM
mrNewt's Avatar
So you do need to clone the new sensors with the ID of the car.
Cool... good to know - I assumed I can just put new ones in and they will just work.
Is there a way to disable the TPMS monitoring system?
I personally never liked this and I would gladly monitor the pressure in the tires myself - I have been doing this for more than 20 years and never had any issues . I don't need a sensor to tell me what to do
Old Apr 13, 2019 | 11:49 AM
Bigg Will's Avatar
None that I'm aware of as I too would have done it a long time ago.
Old Apr 13, 2019 | 12:47 PM
mrNewt's Avatar
Too bad .
Do you remember the Doorman's part number of the sensor and tools you had? Or the sensors?
I was looking on their site and it looks like the sensors they have is only up to 2011 XF... !? Wouldn't previous years to 2012 years use similar stuff?
https://www.dormanproducts.com/p-283...tor%2520Sensor
And found their tool - locally seems to be going for around $300 CAD
Old Apr 14, 2019 | 05:22 AM
Bigg Will's Avatar
Too bad .
The broadcast frequency changed looks like in 2012. My post was from last November so it's the same sensor number you linked to. The tool and sensors.
Old Apr 14, 2019 | 11:46 AM
mrNewt's Avatar
@Bigg Will - Thanks!
Old Apr 14, 2019 | 12:05 PM
Bigg Will's Avatar
Y W..
tiger_reddy
Jul 22, 2018 02:23 AM
wardo5757
Dec 5, 2017 11:27 PM
DevlinC
Feb 14, 2016 03:24 AM
Roger95
Sep 25, 2015 02:05 PM
Cockbain
General Tech Help
Jul 17, 2015 09:22 AM
