Where is the Xeon Control Modual Located
Old Mar 6, 2023 | 03:41 PM
Bond's Avatar
Default Where is the Xeon Control Modual Located
Well candidly I didn't know this animal existed till about 10 minutes ago. After hours of changing out Xeon bulb and ballast along with tracing grounds ect, I was told that this might be an issue. Can anyone point me in the right direction?
Thanks!
Old Mar 6, 2023 | 04:16 PM
Bond's Avatar
Sorry about the double post!! But note the second post I added a line regarding exciter possibly being considered the actual control modual. This is not clear to me. Are they one and the same?
Thanks,
2012 XF
Old Mar 6, 2023 | 10:22 PM
kkurulak's Avatar
Hi Bond,
Here you are. I could be wrong but I'm thinking it might be more a wire, connection or the central junction box as you have already tested to the opposite side and all is working, correct?
Quote from the Service Manual;
"The xenon headlamp system is controlled by the CJB using a control module for each headlamp and an igniter. The control
modules and the igniters provide the regulated power supply required to illuminate the bulbs through their start-up phases of
operation."
Old Mar 7, 2023 | 07:39 AM
Bond's Avatar
Thanks K! OK, so this module I had originally considered the "exciter or ballast", and I had replaced it and yes, tested on other side. Confusing when parts houses show various images not always accurate. Darn, I was hopeful. that I had discovered my root source. Off to the dealer for diagnostic test.
Thanks again!
Old Sep 11, 2023 | 09:07 AM
doublekite's Avatar
How can I access the CJB on my 2012 facelift saloon please?
Old Sep 11, 2023 | 09:43 AM
clubairth1's Avatar
Community Influencer
Best to start your own thread as your question does not belong in this one?
Old Sep 11, 2023 | 09:51 AM
doublekite's Avatar
Thanks for your help.
gibbon
Feb 4, 2020 12:00 PM
Joe Enge
Mar 30, 2019 11:08 AM
Time-Pilot
Apr 17, 2018 08:21 PM
Leet8845
Nov 21, 2017 04:20 PM
magmedia
Apr 7, 2010 05:18 PM
