Window regulator stalling
Old Jun 18, 2020 | 11:32 PM
POD XF's Avatar
Default Window regulator stalling
The drivers window on my XF is malfunctioning in that when the 'up' button is activated, it will go part-way up then back down, usually closes properly on the third attempt. I assume there is an overload function in the system to prevent me crushing someone's head. Is there a usual cause for this on these vehicles, along with a usual fix? Presumably there is a tight spot either in the window channel or the gear train of the regulator.
Old Jul 9, 2020 | 08:47 PM
Carlos Saez's Avatar
Same issue here,
removed the door card, works fine, this is a sign your window regulator motor is dying. It goes halfway up then down, if you keep trying at some point it will get hot and do nothing, if you have the window auto up down function active, you can disable it by disconnecting the battery for a minute, it will work again, the cure for this is changing the whole window regulator assembly.
Old Jul 11, 2020 | 02:54 AM
POD XF's Avatar
Originally Posted by Carlos Saez
Same issue here,
This problem seems to have fixed itself- at least for the time being- so I'm going to leave it alone unless it starts happening again. Might be temperature related perhaps, as we have had much cooler weather over the past couple of weeks, but I won't look a gift horse in the mouth.
Old Jul 11, 2020 | 12:02 PM
carzaddict's Avatar
funny thing is, on my XF, the window would work better in hot temperature. i assume it wasnt the motor, but rather something making it stick, because in cold weather it would roll up 1/2 and roll down as if it hit something
greenestate
Jan 9, 2021 10:56 PM
martek
Sep 13, 2018 06:02 PM
PaulBarrrera
Jan 14, 2015 01:56 PM
perezrp101
May 22, 2009 12:29 PM
