XF 2011
Old Feb 28, 2022 | 05:28 PM
Carmine's Avatar
Default XF 2011
Hi l have a 2011 xf jaguar when l start it up in the morning l get a compressor comes on the front left hand side that last for about 1min then turns off (it's not the aircon as it's switched off) l took it to local Jag dealer they are saying it's my aircon but my little knowledge is telling me something else is happing
Old Feb 28, 2022 | 05:39 PM
Carmine,
I've moved your question from X260 (for 2015 onwards) to X250 (for 2007 - 2015) forum. This is the place to post technical questions about your 2011 model.
Old Feb 28, 2022 | 10:46 PM
BritCars's Avatar
Is there a particular problem?
Any codes ?
Old Mar 2, 2022 | 10:44 PM
Carmine's Avatar
No codes
Old Mar 3, 2022 | 11:54 AM
kansanbrit's Avatar
Secondary air pump noisy perhaps?
Old Mar 5, 2022 | 12:18 AM
Carmine's Avatar
So what does the secondary pump do and what does it operate
Old Mar 6, 2022 | 02:13 AM
coolabah's Avatar
Good question, never heard of it myself either. I googled it and was amazed ! Sounds worth investigating for sure
Old Mar 7, 2022 | 01:14 AM
Carmine's Avatar
Thumbs up
Thanks Kansanbrit I'll have to look into it 👍
Old Mar 8, 2022 | 08:26 AM
kansanbrit's Avatar
It improves emissions during startup.
Old Mar 8, 2022 | 01:59 PM
Six Rotors's Avatar
So if you have a 2011 XF with a 5.0 V8, your engine does not have secondary air pump. As far as I know that is a relic from the 4.2 V8 motors. Down on the left side of your 5.0 ( left as viewed from the front) is a vacuum pump which operates continuously when the engine runs.
The AC compressor is on the other side of the engine (left as viewed from the drivers seat)
Old Mar 8, 2022 | 04:58 PM
coolabah's Avatar
oops yes I forgot to add any useful information from my google efforts !!
Old Mar 9, 2022 | 06:43 AM
kansanbrit's Avatar
Not that then !
Any ideas what it could be?
Old Mar 9, 2022 | 06:44 AM
kansanbrit's Avatar
When you say it 'comes on' what exactly do you mean?
Old Mar 9, 2022 | 07:52 AM
Six Rotors's Avatar
Not that then !
I suspect that it is the AC compressor. The fact that the AC is turned off does not prevent the AC compressor from running---if the climate control system is on auto, or if the defrost mode is selected the AC will run. This is all explained in the Owners Manual
Old Mar 10, 2022 | 06:02 AM
kansanbrit's Avatar
But why would it only run for one minute? And how would he know it's running, it shouldn't make any noise?
Old Mar 10, 2022 | 07:49 AM
Six Rotors's Avatar
Yes we are definitely short of information. The AC compressor on my car is does not make any audible noise. (My wife says I am deaf anyway.)
Seanangus
Dec 12, 2021 11:27 PM
steve123456srm
Aug 3, 2018 09:50 AM
asifr
Apr 25, 2018 02:30 AM
jseaman
General Tech Help
Sep 25, 2017 11:35 AM
scottjr1
Aug 6, 2012 08:45 PM
